My Accord Climate Control Swap
Postby webrun » Mon May 05, 2014 2:33 am
After spending the last year mooching info off of all you guys, here's my first post and first how-to...
After a bunch of reading, last summer I added AC to my '91, but my climate control suffered badly when removing it to add the A/C button to it. After looking at the options, I decided to go with the Accord option. I mostly used the write-up of http://crxcommunity.com/viewtopic.php?t=26741, but I had a couple additions that I feel are useful, so I'll step through what I did.
First off, after seeing what nylumiro24 did in http://crxcommunity.com/viewtopic.php?f=4&t=17526, I really wanted to create a jumper harness as nylumiro24 did because I really didn't want to cut off the harness plugs on the CRX. I wanted to have something plug-and-play and not hack up the wiring on my baby. However, I didn't want to destroy the stock CRX climate control just in case I wanted to fix it up later. So, after hours of searching at mouser.com, I found the correct harness plugs for this. The cool thing is, there is no minimum... you can buy just 1 plug!
At the junkyard where I got the accord climate control, I cut off about 10 inches of the accord harness also. The accord climate control has 2 plugs: a 8 pin and small green 14 pin. The stock CRX harness has 3 plugs: a 5 pin green, 6 pin white, and 13 pin white, all female.
So, here's the parts I bought from mouser. And check it out! $5.90 +$5 shipping... not bad!
Here's the manufacturer web page for the main harness plug. Click on the View 3D PDF link, it's really cool:
Manufacturer Web Page
And here's what showed up:
A/C and fan plug:
Main Plug
Stabs that fit in plugs:
So, taking the chunk of Accord harness and the wire colors from http://crxcommunity.com/viewtopic.php?t=26741 I connected my new plugs to make my harness jumper.
Here's the in-progress fan plug. I'm jumpering the Blue/red blu/blk to eliminate the dead 5th speed of the accord control. Doing it this way will give you the CRX 4th speed for both the accord 4th and 5th positions. I just used a normal wire crimper to crimp these on. Note that the back crimp crimps on the insulation and the front crimps on the wire itself.
If you look at your CRX fan harness, you will see a grn wire in there. This isn't needed on the new fan plug because it's handled differently with the Accord controls, so you will have a blank hole.
Finished fan plug:
Looking at the back of the fan plug, the wire colors from the accord wires get connected as:
__[-]__
[ 1 2 3 ]
[ 4 5 6 ]
1=Blue/Red & Blue/Black
2=Blue/Wht
3=Blk
4=x
5=Blue/Ylw
6=Blue
Continuing on with the main harness plug. Note in the accord harness there are 2 blu/red wire. One is for the A/C and one for the face/foot button selection. You'll need to get your meter out to figure which one is which. With the harness connected to the climate control and A/C button off, the foot/face switch will have continuity to the blk wire when it is selected. This is the wire to put into this plug. Alternatively, you can search for connectivity with an ohm meter between the 14 pin green plug that goes to the climate control and the two blu/red wires. Looking at the back of the green climate control plug, with the 6 wires at the top and the 8 wires on the bottom, the wire for the main harness plug is connected to pin #5 and the blu/red wire to the green a/c plug is the #9 pin.
In the previous write up, there's also discussion about the 2 grn/wht wires of the CRX harness. This issue goes away with the jumper cable.
Again, from the back:
__________
[ 1 2 3 4 5 6 7]
[ 8 9 10 () 11 12 13]
1=x
2=Lt grn/wht
3=ylw/grn
4=blu/red(from face/foot switch)
5=drk grn/red
6=x
7=blk & lt grn/red
8=x
9=x
10=lt grn/blk
11=blu
12=dk grn/wht
13=x
Finished fan/main plugs:
I couldn't find a stab type plug for the green a/c connector, so the one I ordered is a solder connection. The pinout for this is (looking at the back of the plug with the tab inside the plug up):
[ 1 2 3 4 5 ]
1=YLW/BLK
2=x
3=red/blu (from pin #9 of plug of climate control)
4=red/blk
5=red
Here they all are all done:
And, finally, connected to the new accord control, ready to plug into the CRX harness:
But first, I needed to take care of the silly cable connections. As previously done, I used the CRX mixer. After removing the accord mixer and cutting off the screw posts, I attached the CRX mixer upside down(compared to the accord mixer)with some screws. I drilled a little hole into the plastic and just screwed it in. The other write up has a lot more really good pictures that you should look at also.
One side:
and the other. Also note that I removed the brackets from the bottom of the control:
Before I attached it, I had to grind down the metal knob connector so the accord knob would fit. This is very difficult to get right and mine ended up a bit loose. I may end up using the old CRX mixer knob, but it looks kinda bad.
Now, how to mount it... I wandered around at work looking for some sort of scrap metal that could be bent up to attach it. I ended up using 3 of those metal covers from a computer that you take out when you add a video card or something. Easily bent, but fairly sturdy. I then drilled a small hole in them and just screwed them in. I attached them to the accord plastic with some screws. You need to be a little careful, though, of where the screw is going into. The left side isn't too bad, because there isn't much for the screw to damage, but on the right side, there's some electronics or if you go down further and your screw is too long, the defrost button gets screwed.
As much as I hated to, I had to remove the horizontal piece of metal below the climate control so that I could lower it down enough to get those pain-in-the-butt mixer cables attached. I ended up routing the cables up and over the metal frame, just as in the other write up.
In place:
and all done!
Another note is to make sure you test out the lights on the accord control before you get it all in. 2 of 3 bulbs were burnt out from the junkyard, so I went back to the junkyard to pocket some replacements. 2 of the 3 I grabbed were also out.
I've seen in a couple threads where people were wanting the harness plugs to do something like this, so I just wanted to let all you guys know that it is possible to get them.
Here's all the pics:
All pics
The last benefit of this project was that I was suffering some fairly serious alternator whine that I tried and tried to get rid of. While I was digging around getting the climate control to work, I noticed the whole metal frame of the center console wiggled. There's a 10mm bolt at the bottom that connects this framework to the body. This bolt was loose, so I wasn't getting a good ground. Once I tightened it up, alternator whine gone!
webrun
Re: My Accord Climate Control Swap
Postby momikey » Mon May 05, 2014 6:21 am
Dude, nice work and really detailed write up! looks great in there, and I think thats the best mount system I have seen anyone use. I had the same loose bolt on my center console when removing the climate control/radio. Found the mount for it in the spare tire holder from the P.O.!
momikey
Postby jasonolimit » Mon May 05, 2014 11:59 am
Nice and clean work, very OEM look but better. I like it very much!
jasonolimit
Postby NovaVTEC » Tue May 06, 2014 2:26 pm
Very Nice!
NovaVTEC
Postby Baker » Wed May 07, 2014 6:01 am
Well done, good job taking the time and doing it right!
Postby 1990zrx » Wed May 07, 2014 2:43 pm
Great tip with the video card metal pieces! wow so much better than the way i did it lmao :rolleyes1:
1990zrx
Postby kcjohnnyboy » Sun Dec 07, 2014 3:38 am
i'm going to have to find an accord climate control to start this diy to make it plug and play. Great write up otherwise.
kcjohnnyboy
Postby kcjohnnyboy » Mon Dec 08, 2014 4:04 am
how do you go about ordering the plugs from the site? seems a little confusing to me to search the actual part numbers
kcjohnnyboy
Postby webrun » Mon Dec 08, 2014 8:32 pm
If you're looking for the parts that I used, they should show up when you use the following part # in the search at the top of the mouser.com page. Here's some links:
571-171897-1 (fan connecter)http://www.mouser.com/ProductDetail/TE-Connectivity/171897-1/?qs=%2fha2pyFaduiFPumu524fVUO2CCOjGuuOLe4NWoBkeN84H9PHCL32sA%3d%3d
571-170340-3 (pins) http://www.mouser.com/ProductDetail/TE-Connectivity-AMP/170340-3/?qs=sGAEpiMZZMv%252bkWzvOmGqmoJZlLm6Qk9o
571-172508-1 (button connector) http://www.mouser.com/ProductDetail/TE-Connectivity-AMP/172508-1/?qs=sGAEpiMZZMvlX3nhDDO4AIeO8H4MbmW33mvdwLLO46g%3d
571-172777-1 (pins) http://www.mouser.com/ProductDetail/TE-Connectivity-AMP/172777-1/?qs=sGAEpiMZZMs%252bGHln7q6pm4Fqf7MuBHLTu%252b52%252btlEWNI%3d
656-IL-AG5-5P-S3L2 (AC Conn) http://www.mouser.com/ProductDetail/JAE-Electronics/IL-AG5-5P-S3L2/?qs=%2fha2pyFaduiNoRmuG0LYEsHN8lsHkxHfhJucDy%252b30tqPmynN2TxhFJ0z%252bIJhX0Kn
It took awhile for me to find these initially, so if you're looking for different harness connectors it will definitely take some searching.
webrun
Postby NovaVTEC » Tue Dec 09, 2014 3:09 pm
how did you find the correct part # in the first place? :-)b
NovaVTEC
Postby rex-b16a » Thu Dec 11, 2014 7:01 pm
Super impressed at the jumper harness you made. Are those plugs just generic or are they made to replicate honda ones? Also really like the way you mounted it. I just notched the plastic tabs on the bottom of mine to get it to sit close then used zip ties to the top tabs. Mine is pretty solid for now but if I take it back out in the future I'm definitely doing it your way. :-)b
rex-b16a
Postby kcjohnnyboy » Thu Dec 11, 2014 11:51 pm
thanks webrun, that really helps. it took me a little bit to figure it out
kcjohnnyboy
Postby kcjohnnyboy » Thu Dec 11, 2014 11:53 pm
another question, are all the 90-93 climate control wiring the same throughout the whole generation? or, do they differ? someone had told me that they were different but I don't see why they would change it up since Honda back in the day never changed much, if there were changes, they were subtle changes.
kcjohnnyboy
Postby bairdandrew77 » Sat Dec 13, 2014 9:49 pm
Definitely subbing to this. I want to do this swap sometime next year, hopefully I'm not too lazy!
1986 Honda CRX- Sold; 1999 Honda Accord EX- H23A VTEC swap; 1997 Ford F350 crew cab long bed- Sold; 1996 Ford Explorer- Sold; 1989 Honda CRX- minime swap
bairdandrew77
Postby suspendedhatch » Mon Dec 15, 2014 4:05 pm
rex-b16a wrote:Super impressed at the jumper harness you made. Are those plugs just generic or are they made to replicate honda ones?
You'll be shocked to find out (I was) that manufacturers don't make all the little parts for their cars. Everything from plug harnesses to VTEC solenoids, intake manifolds, charcoal canisters, climate control and dash pieces etc etc etc are sourced from outside companies. I was aware of Nissin, Nippon Denso etc but my head just about exploded when I saw VTEC solenoids were made by a non Honda company, being that they were function specific.
suspendedhatch
Postby webrun » Tue Dec 16, 2014 12:35 am
kcjohnnyboy wrote:another question, are all the 90-93 climate control wiring the same throughout the whole generation? or, do they differ? someone had told me that they were different but I don't see why they would change it up since Honda back in the day never changed much, if there were changes, they were subtle changes.
The wiring diagrams on autozone (http://www.autozone.com/repairinfo/repairguide/repairGuideContent.jsp?pageId=0900c1528005f9fc) have a different one for 90-92 vs 93, but I didn't look at how they were different, so there might be some changes with a 93.
webrun
Postby webrun » Tue Dec 16, 2014 12:44 am
rex-b16a wrote:Super impressed at the jumper harness you made. Are those plugs just generic or are they made to replicate honda ones? Also really like the way you mounted it. I just notched the plastic tabs on the bottom of mine to get it to sit close then used zip ties to the top tabs. Mine is pretty solid for now but if I take it back out in the future I'm definitely doing it your way. :-)b
NovaVTEC wrote:how did you find the correct part # in the first place? :-)b
I figured that they were some sort of a standard connector so I kept looking through all the parts on mouser.com for hours until I found them.
webrun
Postby NovaVTEC » Tue Dec 16, 2014 1:36 pm
Now that is some persistence. I always assumed Manufacturers sourced the connectors from Mars.
NovaVTEC
Postby kcjohnnyboy » Fri Feb 26, 2016 8:37 pm
just another help tip i need help from you, you didn't state what wire order or diagram on how and what sequence the colored wires go for the a/c green connector that you soldered.
kcjohnnyboy
Postby Wolf Si » Sat Aug 06, 2016 5:55 pm
Yes, no diagram or order for the green plug???
I'm also running into a problem with the two Red/Blue wires, were you said to ohm between the black and the Red/Blue wires to find the right one. With AC button off and Foot/Face switch pressed, neither of the Red/Blue wire ohm out (no connection). Right now there is a 50/50 toss up of if it is the wire issue or that the AC controller is bad.
Wolf Si
Postby Wolf Si » Sat Aug 06, 2016 6:05 pm
Wolf Si
Postby Wolf Si » Sat Aug 06, 2016 9:24 pm
Ok, I cracked the code for the small green plug.
I don't have pictures yet, but here is the order in ref to the finished picture above that just show the three finished plugs. This is with the pin side facing down. If you have the plug you will know what this means (one side has a pin and the other shown does not)
First one on left is RED/Silver Dots
Second one is RED/Black stripe
Third one is BLUE/RED
Fourth pin SKIP(Open)
Fifth one is YELLOW/Black stripe
Now, here is the kicker (not tested yet) but the BLUE/RED is the "other" blue/red from the other plug.
(Not tested yet, but...) what I pulled together is if you look at your Green Accord plug with 14 wires w/ the side with the wires coming out and the tab on the top (or the 6 wires on the top row) and count left to right across the top where the first one on the top left is #1 (Black Wire) #2 (Lt Green/Silver) #3 (Lt Green/Black) and so on, then the #5 (Blue/Red) goes to the main plug and the #9 (Blue/Red) on the bottom row goes to the small green jumper plug (above).
After I put all the wire in the Main plug, and seen what was left over (RED/Silver dots, RED/Black, BLUE/RED, and YELLOW/Black) then looked back at the picture that was posted...... then it was clear where they went.
Wolf Si
Postby Wolf Si » Sat Aug 06, 2016 9:43 pm
Here is a close up of the small green plug from above.
Wolf Si
Postby webrun » Sun Aug 07, 2016 4:19 pm
Sorry about the missing pinout info for the green a/c plug. I'm not sure why I didn't include the pin info for the blu/red once I determined the correct one for the green plug. I went out and confirmed what you found... the blu/red for the green a/c plug is connected to the #9 position of the green accord main plug. I've updated the writeup to reflect this.
webrun
Postby Wolf Si » Sun Aug 07, 2016 4:33 pm
Thanks for the confirmation, as I have not started the soldering of that plug.
Wolf Si
Users browsing this forum: Yahoo [Bot] and 2 guests
