89-91 Fenders the same?
Postby rev run d » Sat Jun 25, 2016 9:51 pm
I just bought a 91 CRX Si, and it needs a new PS fender. Saw one listed on CL, says parts are from an 89+ Crx Si. Will this fender fit my crx?
rev run d
Re: 89-91 Fenders the same?
Postby jfrolang » Mon Jun 27, 2016 1:42 am
Yes
jfrolang
Site Admin
Postby Baker » Mon Jun 27, 2016 5:49 am
It bolts right up.
Only things you will need to change are the small middle molding/trim and your corner light will not fit right anymore. 90-91 uses a small slide tab on the fender to hold the corner light in.
You can see it described here.
viewtopic.php?f=3&t=6216
Postby rev run d » Tue Jun 28, 2016 7:15 pm
Baker wrote:It bolts right up.
I read that thread but the corner light mount looks the same in the pic.
rev run d
Postby Baker » Wed Jun 29, 2016 5:43 am
rev run d wrote:I read that thread but the corner light mount looks the same in the pic.
You didn't really read it or understand it then.
Look and read again, 88-89 corner lights mount differently to the fender and headlight than 90-91.
Postby kevbo82 » Mon Jul 04, 2016 10:38 pm
the fender itself is the same, where the corner light mounts there are little plastic mounts that pop into the fender, they screw in for the 88-89 and slide in for the 90-91. If you can get the correct clips to match whatever corner light you have you can make either fender work
kevbo82
Users browsing this forum: MSNbot Media and 5 guests
