How To: Wire Tuck
Postby noypistah » Sun Oct 12, 2008 1:21 am
i really want to try this, where can i get the PDF file if there is one?
"The only job where you start at the top, is digging a hole." -anonymous
noypistah
Postby Tango28 » Sat Jan 17, 2009 10:51 pm
can some one help im stuck on FI wiring, whats going to happen with the 15 pin clip?thats still attached to my FI?
1991 CR-X SI
2005 BMW 325i
Tango28
Re: How To: Wire Tuck
Postby JDM88CRXSiR » Sun Mar 15, 2009 3:07 pm
Damn I want a wire tuck so bad, and nobody wants to do th em in So Cal. Who is willing to tuck my car for me? Hit me up.
JDM88CRXSiR
Postby lunalink » Sat Jun 13, 2009 10:04 pm
JDM88CRXSiR wrote:Damn I want a wire tuck so bad, and nobody wants to do th em in So Cal. Who is willing to tuck my car for me? Hit me up.
^^ lol..im working on my tuck right now! just have to pass the bundles through the fender and ill be done..i had no clue when i started but its really simple.. I was taking off my A/C system and decided to do the tuck once i had the dash out.
lunalink
Postby Ef8 Dream » Sat Jul 04, 2009 10:15 pm
I'm gonna give this write up a try even though the bundles of wires scare the [potty mouth] out of me. :/
Ef8 Dream
Postby Rexsi90 » Tue Jan 05, 2010 12:53 am
Question fellas.... I did a wire tuck, but now when I use the turn signals they flash really fast as if they were not plugged in..... I'm assuming, or inducing more rather, that this is because I have extended the wires and the current is too weak for the car to register the lights as being plugged in.... How do I get them back to normal?
Rexsi90
Postby Krix » Mon Jan 11, 2010 2:33 pm
You either have either wired something incorrectly, have a bad bulb or another electrical problem somewhere. Ive had 3 wire tucked crx's and never had any problem with mine.
Krix
Postby Slower Than You » Thu Jan 14, 2010 9:11 pm
Pics no workie.
Slower Than You
Postby KOTUS » Thu Jan 14, 2010 10:34 pm
I'm hoping someone saved them!
KOTUS
Postby kushkommander » Mon Jan 18, 2010 5:46 pm
yeah some pictures replaced in the first post would help wonders, or that pdf if its somewhere around?
its probably still doable with these instructions :D we will see
kushkommander
Postby the bee » Thu Jan 21, 2010 11:47 am
:-)b
the bee
Postby EF8_DREW » Fri Jan 22, 2010 4:20 pm
i have a question? do you need to extend the wores or should they be left alone and untouched?
EF8_DREW
Postby neo27ny » Fri Feb 05, 2010 5:21 pm
I read through the write up and either missed it or it wasn't mentioned. Where do you run the wires through on an Si? I've read other how-to's on this but the ones I seen are all non Si models and have a pre-existing hole with a grommet in it you can use. I was thinking about going through the hole for the loom that goes into the door but that seems kinda awkward. Any ideas?
neo27ny
Postby nihkon » Fri Feb 05, 2010 5:30 pm
On the driver side I went through the grommet for the hood release cable.
On the passenger side, I went through the grommet for the wire loom for the door.
nihkon
Moderator
Postby neo27ny » Fri Feb 05, 2010 8:12 pm
ok cool, i started going through the grommet for the door loom but thought i would see what someone else did first in case there was issues. I haven't started the driver side yet. Thanks.
neo27ny
Postby 88crx386 » Thu Feb 25, 2010 1:42 pm
WHERES THE PICS???????????? I WANT TO DO THE TUCK ON MINES.... PICS WOULD BE GREAT..I KNO THE WRITE UP IS THERE BUT WOULD ALSO LIKE PICS TO .... :evil:
88crx386
Postby alh081 » Thu Feb 25, 2010 2:52 pm
The pics are dead..but you can check out another tuck here:
http://importsnc.com/forums/honda-acura ... -pics.html
They have plenty of pics and should be easy to follow.
alh081
Postby 88crx386 » Fri Feb 26, 2010 1:22 am
thanx mite start 2morrow
88crx386
Postby rex_rex_baby » Sat Apr 03, 2010 12:35 am
i have a noob question. im planning on attempting this but i want to know something. if i do a tuck with my d16 and decide to do a b swap later later later on will i have to re-do anything? or will i be fine?
rex_rex_baby
Postby rex2nr » Sat Apr 03, 2010 7:27 am
You may have to swap some plugs depending on what year B16 you get. You will also have to add a few wires for VTEC. There are probably a couple other changes too I'm unaware of.
-Scott-
projectCRX Sold
1999 Ford Ranger - Project DD 2011 Ford Escape - family/dog/parts hauler
rex2nr
Resto-Modder
Postby rex_rex_baby » Sat Apr 03, 2010 4:03 pm
if anything im gonna go with a 95 gsr swap. my car came with a d16 swap and fully converted to obd-1.. would that make any difference? i would love to start my wire tuck, but i know in the near future i'll be doing a b swap and i wonna make sure i dont have to re-do anything.
rex_rex_baby
Postby MexiChriS » Mon Aug 30, 2010 3:10 am
god damn it, was gonna do this today, and when i came to this 2nd page then went back to the 1st the pics disappeared :cry: Where the hell is this PDF!? Feel teased Downest mentioned a PDF but no where to be found, that would of been a life saver! Might do the one alh081 had posted I guess...
1988 CRX Si (shell) D16z6 OBD1 In Progress <--- Build Thread
1990 Civic Wagon D15b2 (SOLD)
1972 Datsun 240z - L24 w/stock SU Carbs (SOLD)
MexiChriS
Postby Slow Dr1v3r » Mon Aug 30, 2010 10:42 am
Got a question I got a stock 88dx and yes still dual point and wanna do a wire tuck since I dont see myself registering my car anytime soon but when I swap will I have to do the whole tuck again or will i just have to unwrap add wires then wrap again? Also will the tuck make it a really big pain in my ass to add vtec the other two injectors etc :|
Slow Dr1v3r
Postby CRXHFGLH » Wed Sep 08, 2010 12:51 pm
And why ISN'T this a sticky???
EXCELLENT write-up. :-)b
CRXHFGLH
Postby Baker » Wed Sep 08, 2010 12:57 pm
CRXHFGLH wrote:And why ISN'T this a sticky???
It already is...did you look for it?
It's in this forum (Restoration, Cosmetics & Detailing), first thread, the FAQ's ,under "Engine Bay".
Users browsing this forum: Yahoo [Bot] and 3 guests
cron
