What kind of gas do you use?
Postby dmudd » Sat Jun 18, 2011 10:03 am
The e85 thread got me thinking....I personally all ways use premium (93 octane) I couldn't tell you if there war any difference between premium gas and regular gas in my car because i have never used regular. I have a b16 with basic i/h/e few other non engine mods
dmudd
Re: What kind of gas do you use?
Postby KOTUS » Sat Jun 18, 2011 10:25 am
The ED9s -> D16A8 DOHC -> Premium (98 RON)
The ED3 -> D15B4 Twin Carbs -> Regular (91-93 RON)
KOTUS
Postby ohisofly » Sat Jun 18, 2011 4:59 pm
I use the cheap stuff, tried using gas without ethanol mixed in but I didn't really see a change in gas mileage. Well, a change that was significant enough for me to care.
1991 Crx Si - My build thread
ohisofly
Postby Dave_Darling » Sat Jun 18, 2011 5:20 pm
I am pretty certain that all of the US-spec CRXes were designed to use regular-grade fuel. IIRC, the owner's manual for mine said minimum 85 AKI. Yes, 2 points lower than the regular you get in most areas. I've only seen 85 for sale in Colorado, so it's probably a high-altitude thing.
Note that RON numbers are about 4-5 points higher than AKI (which is what US pumps are rated in) for the exact same gasoline.
--DD
Dave_Darling
Postby Nar » Sat Jun 18, 2011 6:14 pm
I usually go with chevron with the lowest grade gas, 87 octane for 3 fill ups and then on the fourth fill i use premium. Don't know why i do this but its just nice to run good gas once in a while. :D
My CRX Si
viewtopic.php?f=26&t=43328
"And the CRX still wins on design; aerodynamic block sander beats lumpy egg every time."
Nar
Postby nurburSTIG » Sat Jun 18, 2011 6:15 pm
Shell 93 for me.
MY BUILD viewtopic.php?f=26&t=31271
"What will probably get you pulled over much quicker is putting HID bulbs in stock halogen housings, as you'll have a metric poo-ton of glare."-Jorsher
nurburSTIG
Postby spyke » Sat Jun 18, 2011 7:24 pm
Unless you're building a high compression engine, or on a tune that was designed for higher octane, there's no point in running above 87 on our little engines. It's what they were meant to run. You won't experience any different in running a higher octane (performance or MPG), a higher octane just = more knock resistance.
RIP: 1988 CRX DX - Y8 mini-me "Cassidy"
Current: 1999 Black & Tan Mazda MX-5
spyke
Postby ollie » Sat Jun 18, 2011 8:50 pm
Spyke=correct.....running premium in a stock crx engine is a waste of money..
Higher octane fuel is used to help prevent detonation.
...Thrashy. said...."Robb, if my car ever breaks down, I'll never have to worry because I can just shout "CRX FLOORMATS!" and within an hour you'll be right there to tell me about yours. 8)" ahhhhhahahahahahah
1989 EF9 project "Backburner" in restoration. :)
ollie
Site Admin
Postby dmudd » Sat Jun 18, 2011 9:07 pm
now that thats settled why do some cars like the 3000gt and catalic require premium...
dmudd
Postby imgoingforit » Sat Jun 18, 2011 9:24 pm
dmudd wrote:now that thats settled why do some cars like the 3000gt and catalic require premium...
Higher compression and boost??
sxysweed wrote:They're good for cool points on NWP and that's about it.
jdmtruong wrote:had some rotas but u know gotta have the real rims
imgoingforit
Postby ollie » Sat Jun 18, 2011 9:34 pm
^^correct
ollie
Site Admin
Postby spyke » Sat Jun 18, 2011 10:15 pm
ollie wrote:Spyke=correct.....running premium in a stock crx engine is a waste of money..
Thank you for this... I was half expecting someone to jump in going, "NUH-UH! My best friend's girlfriend's uncle SWEARS ON HIS LIFE that premium adds as much horsepower as 3 stickers" or something ridiculous like that. I see it all the time on other forums, and hear it from people who pretend to know about cars. :rolleyes1:
spyke
Postby dmudd » Sat Jun 18, 2011 10:52 pm
whats the stock comprssion for our motors including the b16? i know the 3000gt na it 10.1 and it saif premium only.
dmudd
Postby JohnnyBlaze » Sun Jun 19, 2011 8:29 am
dmudd wrote:whats the stock compression for our motors including the b16? i know the 3000gt na is 10.1 and it said premium only.
As mentioned above, the 3000GT is a turbo engine and requires premium to prevent detonation.
Compression numbers= :google:
JohnnyBlaze
Postby madhatr » Sun Jun 19, 2011 2:03 pm
I use what ever i get from work
madhatr
Postby dmudd » Sun Jun 19, 2011 2:10 pm
Not trying to argue but not all 3000gt are turbo only the vr4 are turbo.
dmudd
Postby Dave_Darling » Sun Jun 19, 2011 7:31 pm
Lots and lots of things change the propensity of a given engine to ping. The octane of the fuel matters, of course, as does the ignition timing. The pressure of the ambient air the engine is pulling from (high altitude or low), the amount of boost if any, intake air temperature, how wild or mild the cam is, the combustion chamber shape, the presence or absence of hot spots or sharp edges in the chamber, the number and location of spark plugs, the mixture quality, how rich or lean the mixture is, and on and on and on and on. All of those things affect if an engine pings or not.
Most engines today are built with knock-sensors that can tell when pinging starts. They can then pull timing out (and boost if they have computer-controlled boost) or richen the mixture slightly until the pinging goes away. So they can run higher compression and count on the engine management system to make sure the engine doesn't destroy itself.
Our engines are a little older, and do not have a knock sensor. (Not on a stock US-spec CRX, at least.) So they had to be a little more conservative with the compression and timing and such, to leave some margin of error.
Some even older engines (VW Bug ones, for example) are even more primitive. Because of the sub-optimal combustion chamber design, the very primitive engine management system (centrifugal-only spark advance in some cases, and a single carburetor in most cases) and other factors, they have to run premium fuel when they get over about 8.0:1 compression.
--DD
Dave_Darling
Postby THATREDCRX » Sun Jun 19, 2011 7:59 pm
This thing works if you take the time to tap a spot for the sensor and you can also make your own voltage monitor for the knock. I dont know yet what voltage would be a bad knock but you get the idea.
I had one on a B16 and never got it to read high with 87 all up through @8500rpm but it is still good to have if something with the motor is going wrong or just bad fuel. Performance mods is where it will help the most.
Why let the computer have the most fun with the knock sensor?
THATREDCRX
TERMINATED
Postby asianflava » Sun Jun 19, 2011 9:21 pm
I get the cheapest gas I can find.... for all my vehicles.
91 CRX Si (hers)
89 Civic Si (his)
01 Toyota Highlander (hers)
07 Toyota Tundra (his)
asianflava
Postby dmudd » Sun Jun 19, 2011 9:32 pm
Dave_Darling wrote:Lots and lots of things change the propensity of a given engine to ping. The octane of the fuel matters, of course, as does the ignition timing. The pressure of the ambient air the engine is pulling from (high altitude or low), the amount of boost if any, intake air temperature, how wild or mild the cam is, the combustion chamber shape, the presence or absence of hot spots or sharp edges in the chamber, the number and location of spark plugs, the mixture quality, how rich or lean the mixture is, and on and on and on and on. All of those things affect if an engine pings or not.
Nice write up thanks explained alot
--DD
dmudd
Postby shorty_boy » Tue Jun 21, 2011 2:10 pm
I use mid grade to prevent knocks. I notice a difference in my car. This was the obld and tired d15b6. As of right now, the three stage requires premium. I think that I'll just keeping getting mid and add octane booster to prevent knocking on the crappy California gas. Once I get it back on the road, then I will be able to see a difference.
1989 CRX HF "... and i will call her betsie and betsie will be mine!"
Resurrected 1/15/2012.
Shorty's Mods, Swaps, and Reviews.
shorty_boy
Return to The Lounge
Users browsing this forum: Bing [Bot], fraglerock, Yahoo [Bot] and 3 guests
