What did you do to your crx today?
Re: What did you do to your crx today?
Postby 4drSpankR » Tue Aug 30, 2016 10:49 am
Looked at turbo kits for it. Really getting the itch to tear into this car again. :twisted:
4drSpankR
Postby Mista Bone » Wed Aug 31, 2016 1:03 am
Put old clutch cable back in, car is better than before.
Transmission is wore out though, but I know a guy that can fix it up, as soon as I get caught up!
BoneSpec Transmission
"D" Tranny guru
Mista Bone
Postby tommy » Thu Sep 01, 2016 12:27 pm
Just picked up my tb and sent it along to Maxbore. These old throttle bodies sure are odd looking. Hoping to clear up the idle issue and pick up a couple of hp along the way.
Postby 4drSpankR » Sat Sep 03, 2016 3:23 pm
Whew, what didn't I do. Took it to work so I could completely go over it in prep for race day coming up. Wanted to see if anything need replaced or repaired.
- Tightened the front sub-frame (Stiff motor mounts like to loosen everything up)
- Tightened front cross-member bolts for the same reason.
- Measured RTA bushings so I can order the correct ones. (DA or EF)
- Adjusted shift linkage underneath the car, had a little slack.
- Adjusted the clutch cable, not sure why it took me so long to get that done.
- Set tire psi
- Re-set up the suspension (front/rear) on the alignment rack, didn't realize how far off it was. So glad I bought the Hardrace rear camber kit which made it adjustable. Car now drives so much better.
- Washed entire car and cleaned the wheels.
- Hit VTEC.
It was a good day. :-)b
4drSpankR
Postby AZCRXSI » Sun Sep 04, 2016 7:52 pm
Lifted him off the ground.
Inspected/cleaned the wheel wells...
Rotated tires
Charged battery
Cleaned wheels
Cleaned exterior
Cleaned/vacuumed interior
Oil Change
Techron fuel cleaner / full tank of gas.
1990 CRX Si BUILD THREAD
AZCRXSI
Postby Intertwined » Sun Sep 04, 2016 10:26 pm
Had to cut out both driver and passenger side bolts that hold the front LCA to the subframe......
Then about kicked it when i realized everything is closed and i cant get replacement bolts yet......
Then wanted to kick myself for not getting them before hand..........
Intertwined
Postby 4drSpankR » Mon Sep 05, 2016 8:55 am
Intertwined wrote:Had to cut out both driver and passenger side bolts that hold the front LCA to the subframe......
Have DEFINITELY been there before.
4drSpankR
Postby Ti Rider » Mon Sep 05, 2016 11:19 am
Put in a set of new Maxpow hatch struts ($20 Amazon). But like everything these days with owning a 27 year old car I'd long ago replaced the originals with replacements that used two ball ends. I couldn't find the original mounting hardware anywhere - in my Honda bolt, screw, etc coffee can or my local junkyards. So I went to my local dealer and for a mere $48 I got the two bolts and two plastic end covers (after a week for them to get them).
'89 Blade Silver CRX Si
Member #17
Ti Rider
Postby realitydroid » Mon Sep 05, 2016 10:02 pm
Replaced my cam gear today, after hours of cussing at the car due to bolts that wouldn't budge. lol
realitydroid
Postby frankzcrx » Fri Sep 09, 2016 3:57 pm
Change Oil and Transmission on my 88 Si.
Used Mobil1 5W30 for engine and Valvoline High Performance Conventional 10W30 for Transmission (skip the Honda MTL per Mista Bone).
88' Y49 CRX Si
frankzcrx
Postby Angry » Sat Sep 10, 2016 9:45 am
Cleaned the garage out enough so I can actually roll the poor thing out at some point.
...Going to need some 88 "Style" drivers side seat rails. Mine are rusted solid from a previous sunroof leak.
Blade Silver 88 Si....Buried in the garage.
I like my woman just how I like my roads.... Curvy!
Angry
Postby Sandell » Mon Sep 12, 2016 12:13 am
I cleaned the inside of the car. I'm bought some trunk weatherstripping.
Sandell
Postby realitydroid » Wed Sep 14, 2016 1:49 pm
Did an unintentional flush of my motor when I accidentally botched an oil change on Monday (forgot to check to see if the old gasket from the old filter had stuck to the threads).
Also, this morning I sprayed some dry lube into my ignition. Last night the tumbler decided to start being insanely hard to turn. Easy fix, lol.
Next up: brakes, cv joint, and replacing exhaust.
realitydroid
Postby jacksonww » Wed Sep 14, 2016 11:41 pm
New seat belts installed. I hated to open and use them but it was time.
Sent from my Nexus 7 using Tapatalk
jacksonww
Postby tommy » Tue Sep 20, 2016 8:29 am
Got the throttle body back from Maxbore last night - look how pretty! You could eat off it. Dropped it off at the shop this morning - now have to get it installed, have them fix the awful exhaust job that was previously done to get the dual tips to line up correctly, and hopefully the idle is fixed, I've added a couple of hp, and I can drive it longer than 5 minutes for the first time this year. :burnout:
Postby 4drSpankR » Tue Sep 20, 2016 10:53 am
tommy wrote:Image
So basically, you can come racing now.
4drSpankR
Postby tommy » Tue Sep 20, 2016 11:20 am
LOL. You're persistent! :P
Yep, it's penciled in for Nov; assuming the car runs great, just would have to get a Schroth and nail it in.
Postby Ti Rider » Tue Sep 20, 2016 3:37 pm
Took it by a buddy's shop and got the AC recharged. He even replaced the valve in the low pressure side. Result? Ice cold AC.
Member #17
Ti Rider
Postby AZCRXSI » Tue Sep 20, 2016 4:21 pm
Kind of annoyed with my work... The parking lot has been compromised lately and I just do have it in me to bring the CRX and park it. (e.g. F250 and Tahoe were "misplaced" and never returned).
:twisted:
AZCRXSI
Postby 4drSpankR » Wed Sep 21, 2016 10:47 am
tommy wrote:LOL. You're persistent! :P
Yessir, we have to establish that dominating CRX presence on track day!
(if you're on facebook, PM me your name and I'll invite you to the event page.)
4drSpankR
Postby Nar » Wed Sep 21, 2016 5:45 pm
Looked at it. Because i did some things that involved spending money and waiting for deliveries. Sooooon........ so sooooon :bounce:
My CRX Si
viewtopic.php?f=26&t=43328
"And the CRX still wins on design; aerodynamic block sander beats lumpy egg every time."
Nar
Postby tommy » Tue Sep 27, 2016 1:38 pm
Stopped by the shop; Maxbore's TB is in, and idle is now fine. :bounce:
They sent the car off to the exhaust shop to fix the nasty install that had been done. Then it should be all ok to pick up and drive again, probably next week. :burnout: :)
Postby AZCRXSI » Tue Sep 27, 2016 3:24 pm
tommy wrote:They sent the car off to the exhaust shop to fix the nasty install that had been done. Then it should be all ok to pick up and drive again, probably next week. :burnout: :)
:-)b :mrgreen:
AZCRXSI
Postby tommy » Wed Sep 28, 2016 8:45 am
It's at "KC's Kustoms Exhaust Shop"; with a name like that, you know it's got to be good! :rolleyes1:
They do actually get very good reviews, though the owner is a total douchebag. If they can get the exhaust to look normal, I can deal with the attitude.
Postby AZCRXSI » Wed Sep 28, 2016 11:21 am
tommy wrote:It's at "KC's Kustoms Exhaust Shop"; with a name like that, you know it's got to be good! :rolleyes1:
hahaha
Yes, if they can get it to look like what you want... its all downhill from there... Good luck!
Grab some of my pics as reference pics IF that would help?
AZCRXSI
Return to The Lounge
