What did you do to your crx today?
Re: What did you do to your crx today?
Postby tommy » Fri Sep 30, 2016 3:31 pm
Made an attempt to pick up the car today. Paid for all of the work (ouchie!! :faint: ), but Odyssey was drained. I have an issue somewhere. So will pick it up tomorrow after my other battery is fully charged tonight.
I have to say that KC did a great job - looks like I bought the exhaust this way:
I'm impressed. Hoping to enjoy driving the car a bit next week, though of course, it's quarter end at work, so won't be able to play around too much with it. Have to put on several things and clean it up thoroughly before the EF meet on Oct 22.
Postby AZCRXSI » Fri Sep 30, 2016 4:04 pm
tommy wrote:Made an attempt to pick up the car today. Paid for all of the work (ouchie!! :faint: ), but Odyssey was drained. I have an issue somewhere. So will pick it up tomorrow after my other battery is fully charged tonight.
Looks much better! :-)b You appear to be happy with the results.
What do you think is killing the battery?
1990 CRX Si BUILD THREAD
AZCRXSI
Postby tommy » Mon Oct 03, 2016 8:42 am
Drove it back to the parking lot this morning after I trickle charged the one PC680 (one wouldn't even charge at this point - I guess too much charging over the years). Drove great, but the idle was a bit high (ICV?). I don't really know what the problem with the electrical system is - I'd assume a draw somewhere. I do think that I'll ditch the girly man battery, though - the PC1200 looks like it would make more sense, the mount would probably be pretty easy to switch over, and the terminals can use the same wingnuts that I've been using on the 680 and like.
I still have to break in the ceramic coating on the exhaust - needs an hour of continual idling to bake it completely. Will probably do that tomorrow night and fiddle with things. But if the electric draw is not something easy to identify, like the alarm, I'll have to do a deeper investigation.
Postby Baker » Tue Oct 04, 2016 1:28 pm
tommy wrote:The exhaust guy, who I've been using for a long time, said it was a bitch to get the Tanabe exhaust melded with the MF cat and the dual tips, but I really don't like how far out the tips stick at all.
You didn't end up using that Thermal Research exhaust?
Postby tommy » Tue Oct 04, 2016 3:58 pm
Don't send me a letter bomb yet. If you go through this thread, I did what AZ had done with his car (so it's really his fault, not mine!) - had the Thermal's tip hacked and got a dual tip MagnaFlow welded on. I like it better, but it's still your exhaust, just with a lower key non-grapefruit shooter.
Postby jacksonww » Thu Oct 06, 2016 2:43 am
Got these in the mail today. My Mugen pedals slip too much especially with wet Oregon feet.
What I'll be doing tomorrow. Took about a month to get made but it seems like it was worth it.
Sent from my Nexus 7 using Tapatalk
jacksonww
Postby tommy » Thu Oct 13, 2016 8:36 am
Work let up a little and I was able to leave in daylight, so I was finally able to cure the ceramic coating on my exhaust. And only 3 months and about 10 miles on the odo since, but better late than never. Took an hour of idling in the parking garage, luckily on the 3rd floor where I didn't see anyone.
While it was doing that, I swapped out the lugnuts to Muteki SR48s in neochrome (gotta have some bling on a black car), verified that the base of the steel battery frame from West Coast Batteries is the same for the Odyssey PC1200 as it is for the PC680, and got in a couple of rounds of Temple Run 2 to close things out.
Current line of thinking is that I leave the car as is, with the slightly high idle (about 1050, when the Bisi cams aren't making it a bit lumpy), and do a battery disconnect when the car's not running. The voltage didn't drop at all during the hour, so that makes it a pretty good sign to me. And will keep the P1200 in the car as well as a back up, for driving to/from the PA meet next week, then decide if I want to try to understand the battery drain and high idle this year, or put it away for the winter and deal with it next year. We'll see how lazy I feel...
Postby 4drSpankR » Sun Oct 16, 2016 9:52 am
Replace the hood cable, should have been done years ago. Worst part is, I've had a replacement cable for the last 4+ years... Also removed the washer bottle and lines, trying to clean the bay up a little more. Threaded in a bolt/washer combo for my Odyssey battery positive cable, kinda had it vibrate off last time I drove. 85A motor mounts LOVE to vibrate things loose... Cleaned the wheels and checked tire psi.
Almost ready for track day Nov. 11th!!
(See AutoX section for more info!)
4drSpankR
Postby Cementups » Sun Oct 16, 2016 12:20 pm
4drSpankR wrote:Replace the hood cable, should have been done years ago. Worst part is, I've had a replacement cable for the last 4+ years... Also removed the washer bottle and lines, trying to clean the bay up a little more. Threaded in a bolt/washer combo for my Odyssey battery positive cable, kinda had it vibrate off last time I drove. 85A motor mounts LOVE to vibrate things loose... Cleaned the wheels and checked tire psi.
I'm confused. AutoX or track day??!? They are not the same.
Cementups
Postby tommy » Mon Oct 17, 2016 7:49 am
Track day. Go to the track/autox subforum for details; that's what he meant by his post.
Postby 4drSpankR » Mon Oct 17, 2016 10:54 am
tommy wrote:Track day. Go to the track/autox subforum for details; that's what he meant by his post.
Correct. I typed that quick, sorry about that brokenUPS. :biggrin:
4drSpankR
Postby Cementups » Mon Oct 17, 2016 8:23 pm
Sorry, I don't go in that forum often. I was hoping it was track and not cone-dodging. Personally I am not a fan of cone-dodging.
Cementups
Postby 4drSpankR » Tue Oct 18, 2016 10:44 am
Me either. But you sir, are in luck. It IS an actual track, I'm not a fan of the whole cone thing either. It's at the New Jersey Motorsports Park. I'll send you a FB invite.
4drSpankR
Postby JDMCrx91 » Fri Nov 04, 2016 10:32 am
Got her spal power window kit and im gonna be using OEM RHD power window switches. Ill make a how to.
"Correct Me If I'm Wrong... That's Why I Joined" Crxcommunity.com
1991 Crx Si(turbo)
My Build Thread http://crxcommunity.com/viewtopic.php?f=26&t=34412
1991 Crx Si (sleeper) 3/17/13
viewtopic.php?f=26&t=64610
1992 240sx coupe
JDMCrx91
Postby jacksonww » Mon Nov 07, 2016 2:27 am
Leather with grey stitch speedo cover finally fitted.
jacksonww
Postby jacksonww » Mon Nov 07, 2016 2:28 am
jacksonww
Postby jacksonww » Mon Nov 07, 2016 2:29 am
jacksonww wrote:Leather with grey stitch speedo cover finally fitted.
Sent from my 0PJA2 using Tapatalk
jacksonww
Postby 4drSpankR » Sat Nov 12, 2016 5:35 pm
Tracked it at the New Jersey Motorsports Park. First time doing this and was an absolute blast!
https://youtu.be/aw3OEhUYh24
This is a rear shot from my last run of the day. That's a SRT8 Challenger behind me
4drSpankR
Postby AZCRXSI » Sat Nov 12, 2016 6:56 pm
4drSpankR wrote:Tracked it at the New Jersey Motorsports Park. First time doing this and was an absolute blast!
https://www.youtube.com/watch?v=Jwac1JNsS20&feature=youtu.be
Very cool video! Thanks for sharing! :-)b
What were your lap times compared to the SRT8? Looks like a very fun day!
AZCRXSI
Postby 4drSpankR » Sat Nov 12, 2016 7:16 pm
Honestly, I'm not sure. There were a total of 4 runs with the first 2 (for me at least) were spent trying to find shifting points, the racing line and all that. I've never pushed the car that hard and that in itself was a whole new experience. The next time we go I'll pay more attention to the track times.
If you've ever worked to improve your car, you NEED to do this. It is so unbelievably fun!!
4drSpankR
Postby Cementups » Sat Nov 12, 2016 10:39 pm
The racing lines aren't near what you would think they are your first time on the track. I had a pretty rude awakening my first time out. Once I got an offtrack excursion out of the way, the guy with me put me on the right track. Funny thing is, sometimes the fastest way around the track is the longest way.
Glad to see you had an awesome time. :-)b
Cementups
Postby 4drSpankR » Sun Nov 13, 2016 10:38 am
Yeah I had a few moments I thought I was going off, I think a rear sway bar is in order soon. Way more fun than drag racing that's for sure!
4drSpankR
Postby 4drSpankR » Sun Nov 13, 2016 1:26 pm
https://youtu.be/A2gax9Hsz6E
Same run, but with the view from the front of the car.
4drSpankR
Postby Intertwined » Mon Nov 14, 2016 2:10 pm
Traded my 89 (253K) for a 91 Sedan with 114/115K miles, its been MPFI swapped and wired for vtec already.
Intertwined
Postby Robb » Mon Nov 14, 2016 2:37 pm
Replaced igntion switch
The part came in today so I went ahead replacing the part.
1. Removed negative battery terminal
2. Remove under fuse cover and console covers
3. Locate and asses old switch
4. Disconnect plug in fuse panel
5. Disconnect harness plug
6. Another plug to remove - 1 screw
7. Switch plug removed
8. Cleaned inside - black crap
9. Look how badly worn the contacts were ! wow ! :o
10. New OEM Honda part
11. New part installed :)
12. Also cleaned the column covers
Voila startup video
https://www.youtube.com/watch?v=GzzmIkP ... load_owner
Robb
Return to The Lounge
Users browsing this forum: Google [Bot] and 2 guests
