Axle Seals (2) & Front Center Motor Mount
Request parts for your CRX here.
Postby ChiRX » Tue Apr 11, 2017 11:40 am
Hello,
I have a 1991 DX (automatic) that is leaking oil / ATF.
I took it to a trusted shop and they told me it needs new Axle Seals; of course Honda has discontinued the OEM parts...
They also discovered that I need a Front Center Motor Mount... also discontinued...
Hoping someone here can be a lifesaver.
Thanks!
Michael in Chicago
"Cars and cameras are the two things I let myself be materialistic about. I don't care about other stuff."
~Louis C.K.
ChiRX
Re: Axle Seals (2) & Front Center Motor Mount
Postby ChiRX » Tue Apr 11, 2017 2:33 pm
UPDATE:
The shop called me to say that they found a suitable aftermarket supplier for the seals (with a warranty).
Just looking for the motor mount at this point. There are aftermarket options for this part as well but my mechanic really wants to try to find the OEM part (he's had bad results from installing aftermarket mounts in other vehicles)...
~Louis C.K.
ChiRX
Postby Mista Bone » Tue Apr 11, 2017 11:43 pm
That front mount is about the most useless thing.
Back to the axle seals, likely the same as 92-00 with a different middle prefix. So if looking up by the original OEM part number it might not be updated/backdated in some systems.
PL3
P20
P4A
All the same parts...
BoneSpec Transmission
"D" Tranny guru
Mista Bone
Return to Parts - Wanted (WTB)
