Crx siR from Spain
Crx siR from Spain
Postby Noahprinceluk » Wed Jan 04, 2017 9:49 pm
Hello all, after reading a lot of post and make some questions, it's time to show my EE8 Crx SiR(edm EF8).
I bought the car last summer with 65k miles (now 70k) in a extraordinary condition from an old woman, all OEM with any rust (only in the radiator and rear rotors). Since i bought it i ordered a Tein street advance coilovers, (lowered 2.5") then i found a nice set of 16" OZ superleggera with michellin pilot sport 3 and mishimoto full size radiator with Spoon Sports cap, air/con deleted, rear wiper deleted and last thing a Momo tuner steering wheel. (The car weights now 2055lbs without fuel)
Future mods: (i'm planning to get 175-180hp&118lb/ft, currently 157hp&108lb/ft at the crank in the dyno)
Custom 60mm cat-back with sport-cat
Itr manifold+throttle body w/ k&n panel filter
Brembo OE Spec 10.2"+9.4" rotors and pads.
PLM (Toda rep) 4-2-1 2.5" Header
Brand new polybushes and motor mounts
Goodbridge stainless-steel brake lines with motul rbf600
Ceramic stage1 clutch w/ 10lbs flywheel
Hondata s300 v3 (w/ obd1 conversion) with a proper tuned
InnovativeMounts competition traction bar (da spec)
Mfactory Helical LSD
subir fotos a internet
Any advice is welcome! (I'm thinking about whether it's worth buying the Lsd, the traction bar and in the clutch)
Thanks!
Noahprinceluk
Re: Crx siR from Spain
Postby Gr8_EE8 » Wed Jan 04, 2017 11:02 pm
Clean EE8 you have there. Very clean seats, too... I thought I would comment on your upgrade list:
-ceramic clutch NO. You will not like it on the street. I have a Spec 3 in my EE8 now, and I can't wait to replace it with a stage 2.
-ITR manifold and tb YES! People will say not to use them on a b16, but I love the itr mani and tb in my EE8.
-LSD and innovative trx bar are the best thing you can do for traction. It is money well spent. I did a MFactory lsd install a couple weeks ago for a friend, it is a really nice unit.
-the Y1 transmission with the EDM 4.133 ratio final drive is too tall in the gear for street driving. Consider the 4.4 ratio, it matches well.
I also suggest ctr or itr cams with itr valve springs to work with the new upgrades. I have all three available for sale if you want to pm.
You can make 180 hp with these mods for sure.
Gr8_EE8
Postby Tasos_7R » Thu Jan 05, 2017 2:43 pm
This is an amazing condition ee8 you got there!! Well done!! :-)b
I agree that you don't need a ceramic clutch. For your power goals i'ld stay with oem honda. I recently replaced mine with a stage 1 Exedy clutch and even this feels a little harsh for every day driving (at least for my taste). So stay oem. :wink:
Also the Innovative traction bar really makes a big difference. The front end of the car feels amazing after installing it.
How are the Teins in terms of comfort??
Frost White CRX 1.6i-VT EE8
Tasos_7R
Postby Noahprinceluk » Thu Jan 05, 2017 4:47 pm
Gr8_EE8 wrote:Clean EE8 you have there. Very clean seats, too... I thought I would comment on your upgrade list:
Very thanks for the advices! So then i'll keep the oem clutch, and since the engine only have 70k miles, i like to keep it closed, this is why i'm not going to put some ctr/itr pistons, cams, etc.
Noahprinceluk
Postby Noahprinceluk » Thu Jan 05, 2017 4:51 pm
Tasos_7R wrote:This is an amazing condition ee8 you got there!! Well done!! :-)b
Okey i'll stay oem haha
The teins? They are sweeeeeet, they feels like you are in a car with sport shocks not with coilovers! And the car goes flat in corners.
I recommend you for street driving, the spring rates are f:6kg r:3kg with 32 leves of hardness settings.
Noahprinceluk
Postby Tasos_7R » Fri Jan 06, 2017 3:13 am
Thanks for the feedback on teins. I want a more comfortable suspension than the one I got. I was looking at KW v1 but I ll have to think about the teins too now.
Tasos_7R
Users browsing this forum: Baidu [Spider] and 3 guests
