BannisteR's '90 EF7 a slow and painful build...
Re: BannisteR's '90 EF7 + Some Japan and S13 Coverage
Postby Crxhenson » Wed Apr 22, 2015 4:37 pm
Welcome back to VA! Hope I get to see these beauties in person some time. I'm working on a local crx meet. Hopefully you can make it.
Crxhenson
Postby rickapl » Mon May 04, 2015 11:30 pm
O I like the sound of a VA CRX meet that would be cool, but you'd have to do a goood job of spreading the word.
rickapl
Postby BannisteR » Tue May 19, 2015 12:38 am
Update with the coilovers... I ordered the two different part numbers for the tophats, PRH08-31S60 and PRH08-31S70 according to Tein's website one is for the front and the other for the rear. Well they are the same, all the same hardware... So if you are needing Tein tophats, you can order two sets of either P/N.
With one collar taken out and adjusted all the way down, the car sits a little bit lower than stock. Once again, I'm in the market for some coilovers. They are a real nice design, but I would like to be about 2 inches lower than these coilovers can do.
fraglerock wrote:Amazing... looking forward to more updates.
Thank you!
sloppyclock wrote:Did you hook up the ebrake cables for the Wilwood kit in the rear? I know they're slightly longer than stock so I'm curious on how you did it.
Yes I used the wildwood kit, the cables are looped a little longer between the shell and the tank.
Crxhenson wrote:Welcome back to VA! Hope I get to see these beauties in person some time. I'm working on a local crx meet. Hopefully you can make it.
Thanks man, well the Silvia will be at Springfest 6 at the Virginia Beach convention center on June 6th. It will be at the Sumospeed booth.
rickapl wrote:O I like the sound of a VA CRX meet that would be cool, but you'd have to do a goood job of spreading the word.
Yeah that would be nice, depends on when it is and if I'd bring mine out.
*SUMOSPEED* *HIGHWAYSTAR*GARAGE*
http://crxcommunity.com/viewtopic.php?f=26&t=43933 <-- EF7 build/Japan Coverage!
90 EF7 CRX
89 S13 Silvia K's
BannisteR
Postby BannisteR » Wed Jun 10, 2015 8:02 pm
If only it was functional at this height ...
Here are a couple pics from when I was putting the Teins together as ell as the Hardrace uppers.
Also snapped a couple pics of the 4Runner after I installed some Bilsteins as well as the new TRD Pro wheels 8)
90 EF7 CRX
89 S13 Silvia K's
BannisteR
Postby dmlemus » Sun Jun 14, 2015 10:53 pm
good looking suspension setup :-)b
89 CRX Si Build Thread
http://www.crxcommunity.com/vi...29182
B R I D G E P O R T • B U I L T
"Painting is an infinitely minute part of my personality."
-Salvador Dali
Check out my Store!
http://onpointcali.bigcartel.com/
J's Racing /// Active Traction Service /// SunLine Racing
dmlemus
Postby BannisteR » Fri Jul 17, 2015 5:11 am
Nothing too exciting has been going on with the car lately, I did however receive a part in the mail I've been waiting on for a little over two years, yes you read that right two years. I had chalked it up as a lost cause but my brother hit me up saying I got something in a tube in the mail... Well it was from Hardware909. The billet oil dipstick finished in anodized black. I'll get pics this weekend of it and the slow progress on the car.
I've pulled the TEIN Street Advance Dampers off the car as they do not get as low as I like the car to be. there is about an inch of wheel gap. Where I know that would be "functional" I like to be low, with minimal wheel gap. So my next set of coilovers I plan on picking up are Fortune Auto 500 with Swift springs. They are a great combo and have a set on the Silvia. Great customer service and their warehouse is within an hour distance from me.
I've also run into an issue of little to no fuel pressure. when I turn the key on I can hear the fuel pump prime, then shut off, I then turn the car over where its very hesitant to turn over. I noticed that the fuel pressure was around 20psi when attempting to turn the car over, now its around 4psi... Everything fuel wise was replaced when the motor was dropped in. Hopefully its something dumb and can be corrected easily...
dmlemus wrote:good looking suspension setup :-)b
Thank you, they looked very promising and I was stoked to find them when I did, but sadly they aren't up to my standards when installed on the car.
90 EF7 CRX
89 S13 Silvia K's
BannisteR
Postby Josip » Sun Sep 06, 2015 5:59 pm
Got any pictures of that combo of Fortune Auto 500?
Josip
Postby BannisteR » Sun Oct 04, 2015 11:07 pm
Haven't done much with the CRX lately, most of my attention has been focused on the Silvia. This weekend I wanted to do more but the weather has been straight garbage. Drilled holes for the aerocatch latches and cut holes in the hood for them to mount on the hood. I still need to drill the holes to mount them to the hood but the hardest part is out of the way.
I swapped the tires from the CPR's to a set of Work Meisters I picked up when I was in Japan. They are 16x7+27, fronts have the 10mm spacer and rears are no spacer. They fit awesome on the car.
Josip wrote:Got any pictures of that combo of Fortune Auto 500?
I don't have any suspension just yet. I had a lead on a set but moved too slow, they sold before I could purchase them.
90 EF7 CRX
89 S13 Silvia K's
BannisteR
Re: BannisteR's '90 EF7 Back from Japan with a few updates
Postby Josip » Thu Oct 08, 2015 11:13 am
Well it doesnt matter if you didn't catch those suspension. Btw, car looks really nice, even with that dust on the hood! :bounce:
Is that real carbon?
Edit : Do you have flickr acc?
Josip
Postby BannisteR » Fri Oct 09, 2015 5:15 pm
If you caught in one of the previous pictures in the back vent of the hood you may or may not have noticed something a little different in place of the Skunk2 manifold setup. Another piece I've been keeping somewhat quiet until it was on the car was a set of M's Factory ITB's off a DC2 ITR. They were used and came with almost everything to be "bolt in," I cleaned them up and swapped out the fuel setup for my current and polished up the horns a little. Car fires up with them but I still need to figure out some sensor placement and clean up of the rest of the bay. Overall I'm quite pleased with how they look in the bay, I'll have to get the car re-tuned to feel the difference and cannot wait.
I should have a couple more updates next week :fingers crossed:
Stay tuned...
Josip wrote:Well it doesnt matter if you didn't catch those suspension. Btw, car looks really nice, even with that dust on the hood! :bounce:
I should have that worked out shortly, and yes real carbon. J's Racing hood only fiberglass portion is the minimal skeleton underside of the hood.
All these pics are posted from my filckr
90 EF7 CRX
89 S13 Silvia K's
BannisteR
Postby Josip » Sat Oct 10, 2015 3:20 am
Uh, I bet you got some freakin sound from those ITB's. Right? :bounce:
PM me your flickr?
Josip
Postby crxtone » Sat Oct 10, 2015 8:34 pm
Boss 8)
'90 CRX EF7
'91 BMW 318i TOURING
crxtone
Postby BannisteR » Wed Oct 21, 2015 4:55 pm
This past week/end has been busy as hell. I received a few parts in the mail, one of which was a bran new ITR valve cover. Good ole UPS played catch with it and it was destroyed by the time it came to the house :evil: Luckily the seller is awesome and is getting it all sorted out and sending me a new one. Two other items came in the mail as well for it which I'll be sharing in the near future (delivered by UPS and not damaged :shock: )
Josip wrote:Uh, I bet you got some freakin sound from those ITB's. Right? :bounce:
PM me your flickr?
I started the car with them and shut it off, no coolant hooked up at the moment, but they do sound pretty awesome.
FlickR is abannister6, nothing too fancy on there lol
crxtone wrote:Boss 8)
Thanks Tony!
90 EF7 CRX
89 S13 Silvia K's
BannisteR
Postby BannisteR » Thu Oct 22, 2015 12:34 am
One piece I'm stoked to have finally arrived in the mail the other day is my new coilovers. Yes this is the third set of new coilovers for the car, but these are it. Custom ordered Fortune Auto 500 series with optional Swift Springs. I ordered them when I went to their open house meet a few weekends back. Got a little attention with the Silvia there as well :wink:
I should be installing them sometime this week.
And a shot of the two girls together. Beauty and the beast if you will...
I'll be slowly plugging away at the CRX and prepping the Silvia for next month and possibly be re-tuned before then. Still the CRX is on the back burner for attention...
90 EF7 CRX
89 S13 Silvia K's
BannisteR
Postby tommy » Thu Oct 22, 2015 6:44 am
Very nice! That's the setup I'm interested in.
Can you post what rates you got, how the install went, how you like 'em after you've had them on a while?
Am driving right by them in a couple of weeks and thinking about dropping by to discuss what i'll probably be ordering in the spring with them.
Postby BannisteR » Mon Oct 26, 2015 12:51 pm
Not that its tough to put coilovers on, but I got them in on Saturday.
Cleaned all the dust off from cutting the holes for the Aerocatch latches as well
Awaiting a new throttle cable bracket to be made so I can put that into position for the ITB's.
Once I get the Silvia ready for Simply Clean in FL I'll be back to focusing on the CRX. Getting all the wiring straightened out and preps for paint (whenever that may be)
tommy wrote:Very nice! That's the setup I'm interested in.
They are a very nice setup, have them on the Silvia as well, just didn't get the Swift spring upgrade with them. The spring rates are 12 and 8.
Review wont be anytime soon as the car isn't registered and really hasn't been driven in a few years, and that was pretty much around the block...
90 EF7 CRX
89 S13 Silvia K's
BannisteR
Postby tommy » Mon Oct 26, 2015 1:25 pm
No problem on the review, thanks for the info. Funny, our cars are fairly similar in a lot of ways. I don't have nearly the engine work you do, but suspension and appearances are kissing cousins. :D
Postby ghg78 » Wed Nov 11, 2015 2:51 pm
Is the buddy club still super loud with the silencer in it?
ghg78
Postby jdmhondamotive » Fri Nov 20, 2015 1:52 am
awesome build bro! nice 4th gen Runner. I too have a lifted Runner, 3rd Gen though. Keep up the good work!
jdmhondamotive
Postby Crxhenson » Fri Nov 20, 2015 11:44 am
Will you be painting while car the color of the bay?
Sent from my SCH-I545 using Tapatalk
Crxhenson
Postby BannisteR » Fri Dec 11, 2015 3:14 pm
ghg78 wrote:Is the buddy club still super loud with the silencer in it?
Its loud but without the silencer its LOUD! Still could use an Apexi ECV or something to minimize the flow when needed (passing police, pulling into neighborhoods that are quiet)
jdmhondamotive wrote:awesome build bro! nice 4th gen Runner. I too have a lifted Runner, 3rd Gen though. Keep up the good work!
Thank you! and that's a nice looking 3rd gen :-)b
Crxhenson wrote:Will you be painting while car the color of the bay?
Yes the car will eventually match the bay (Championship White)
90 EF7 CRX
89 S13 Silvia K's
BannisteR
Postby ghg78 » Tue Dec 15, 2015 2:55 pm
Good call on the ECV. Totally forgot about that. Thanks for the input, I think that made up my mind on what exhaust to run.
ghg78
Postby BannisteR » Sun Mar 27, 2016 12:12 am
Back again with a couple updates! Ive been slacking as it seems to be the norm sadly. Not a whole lot of new things but little is better than none. First off I'd like to thank the homie mportedcivicsi(NWP) for the opportunity to purchase one of my dream parts. Never would I have thought I'd sit in one let alone purchase for my own project a Spoon reclineable seat. Only crappy thing is its just one, and I need another so my interior will be complete again.. On to other parts/updates Ive been laying out how I'm mounting up and hooking up my AP1 cluster as well as getting the wiring figured out for it. Wiring is not my specialty and I dislike it with a passion :? I also will be adding a defi display to read things with a little more accuracy, more of that later...
Spoon goodness!
I'm also a huge fan of Vertex steering wheels, I bought my first Vertex while I was in Japan and since have purchased 6+ Vertex steering wheels. My favorite has always been the 10 star and I finally found a blue 10 star for a steal!
Decided to move her from the neglected side of the garage so I have a little more room to work on her. So far I haven't utilized this space to work on it...
Yes, I did cut my Spoon hoses to put in a temp sensor adapter. Why, because gauges are super do'n it that's why.
90 EF7 CRX
89 S13 Silvia K's
BannisteR
Postby Hondateam » Sun Mar 27, 2016 12:45 am
Would you like to see my CRX?
Hondateam
Postby vanrij » Thu Mar 31, 2016 12:12 am
Nice find on the Spoon reclinable seat. Those are hard to come by! I hope you find another one, but if not your Recaros are pretty bad ass too.
