AZCRXSI's Build Thread (1990 Y-49 CRX Si)
Postby AZCRXSI » Sat Oct 08, 2011 6:29 pm
Well, I thought it best to put something down on paper (so to speak) and start a build thread. As some of you may recall, I joined the forums not too long ago in the hope that I could find a specific year and color combination of CRX. That was a 1990 Y-49 Si… I chose the 90 because I thought it would be a better fit for me down the road for what I wanted to do with the car. Rear disc brakes are a nice addition along with the ability to swap in the EDM cluster gauges so that I have a tach that goes up to 9k rpm.
I used to have a set of EFs in the mid-90s and we owned a Y49 CRX up until February 2005 when I sold it for a MINI Cooper S. (space issues) I think I was probably depressed for some time after selling that CRX… I don’t have to go into why as it seems obvious on this forum.
So after reading up on this forum and a few others to regain some knowledge I lost over the years, I decided to cast a net and see if anything came up. This in the form of a signature stating that I was looking for a ’90 Y-49 Si… Being skeptical in nature, I did not believe I had a shot in **** in finding a decent chassis to start with…
Then one evening, I received a Private Message via these forums and decided to open it up! Low and behold it was Dave asking if I would be interested in his ’90 Y49 Si because he was thinking about selling his. After many PM exchanges, I learned about his car in great detail and then the pictures came in… Very impressive to say the least… Way above what I was shooting for to be honest.
Long story short, my buddy Ryan and I flew up to Northern California to meet Dave and purchase his Y49 CRX on a Saturday morning and drove the car back to Phoenix, AZ. It makes one a little nervous driving an unknown car 85mph on a freeway for 10 hours and 730 miles. But it was quite obvious Dave took care of the car and he had receipts on the car going back to when it was originally purchased. Crazy… In the end, we made the trip back to Phoenix without a single hitch and Mango Bango performed admirably!
You can read up on his post regarding the sale of Mango Bango to me here.
Toward the last couple of miles on the trip, the linkage appeared to go south a bit but we were able to limp him home leaving it in 5th most of the way.
Yesterday, I decided to look under the car to see what was going on. Justin is nice enough to sell me a new linkage so that is on the way as well. But I was able to see what was wrong with the car and fixed him to the point where I could take the car in to get it emission tested and registered in Arizona.
I’m digging the new 2.5t floor jack I bought from Harbor Freight… mighty cool…
I found this… turns out the nut on the main shifter bolt fell off on the trip back which contributed to the sloppy shifter… $2 worth of nuts and washers from Ace Hardware tightened that up for now.
The motor has 229k on it and appears to be growing tired… It lived a good life… I gave him an oil change, but I am on a limited timeframe with the A6. It’s our 3rd Car now so he will not see too much action which should buy us some time.
But before the motor comes in, I want to upgrade the brakes with rotors, pads, SS lines. Dave had the car setup with Ground Controls and Illuminas which are a great setup for the CRX. So the only items I want to add to the suspension is possibly a rear swaybar and a front/rear camber kit. Of which, Dave was gracious enough to give me the rear camber kit and Neuspeed strut bar he had on him. Then, after that, I have some 16 inch wheels in mind with 205/45 tires to assist with the handling and braking duties.
I am a big believer of getting out of trouble quicker than I got into it. On my last build (’90 HB Si), I threw the motor in first and that motor had its way with the car.
So thanks for the long read… I promised the wife I would not do too much with the car from now until March-April since we thought it would take much much longer than it did to find a car. So I plan to just enjoy him when I can in this trim until that timeframe.
1990 CRX Si BUILD THREAD
AZCRXSI
Re: AZCRXSI's Build Thread (1990 Y-49 CRX Si)
Postby thiser » Sat Oct 08, 2011 6:46 pm
So clean for so many miles! Good luck with the build.
Rice is not so nice!!!
thiser
Postby AZCRXSI » Sat Oct 08, 2011 6:48 pm
Ok, much to the wife’s dismay, I decided to start cleaning the car up from the trip back. I lightly went through the interior as I want to focus on that in more detail when time permits. There are random plastic pieces that need to be replaced so that should not be too hard to accomplish.
On the exterior, I washed him down, I went over him with a clay bar and quick detailer, polished him, waxed him and applied back to black. Below are the end results… he cleans up well!
Trunk area:
Interior Shots:
Exterior Shots:
I wonder if the MINI is jealous now?
Neuspeed strut bar is in now… Yes, I need to detail the engine bay… that is next on the list…
Cheers!
AZCRXSI
Postby 288REX » Sat Oct 08, 2011 7:43 pm
Nice clean Crx! Just fyi you can swap an Edm cluster into an 88-89 just as easily as a 90-91. Glad to see another Arizona guy on here!
288REX
Postby Robb » Sat Oct 08, 2011 9:58 pm
Looks nice stock
Robb
Postby AZCRXSI » Sat Oct 08, 2011 10:01 pm
288REX wrote:Nice clean Crx! Just fyi you can swap an Edm cluster into an 88-89 just as easily as a 90-91. Glad to see another Arizona guy on here!
Thanks!
Time to represent AZ! hehe
Really? I read a couple of threads on the 88-89 where people had to change out the entire cluster pod... and then the next issue was the pod fitting on the 88-89 dashboard? So some people had to swap out entire dashboards to make everything fit. Now, mind you, I have no idea what I am writing, just repeating what I read.
Good to know I guess!
AZCRXSI
Postby CDUB » Sat Oct 08, 2011 11:09 pm
Ditto to what my bro said (288REX) - extremely clean CRX and welcome!
1988 Honda CRX Si
My 88 si
CDUB
Postby Its me DUB » Sat Oct 08, 2011 11:32 pm
Looks great Jeff! Man, you've already got 3 CRXs in here for a mini meet. :P
Is that pin stripe red or just the glare? If so, weird... if not, I am tired...
Its me DUB
Grill Master
Postby dmlemus » Sat Oct 08, 2011 11:57 pm
wow...that's stocky clean!
89 CRX Si Build Thread
http://www.crxcommunity.com/vi...29182
B R I D G E P O R T • B U I L T
"Painting is an infinitely minute part of my personality."
-Salvador Dali
Check out my Store!
http://onpointcali.bigcartel.com/
J's Racing /// Active Traction Service /// SunLine Racing
dmlemus
Postby 288REX » Sun Oct 09, 2011 12:59 am
AZCRXSI wrote:Thanks!
You don't need to change the cluster cover(only an 88-89 would need to swap as those are more square), the dash boards are the same for all 2nd gens. Like others have said though, your car is so clean, I would leave it alone lol!
288REX
Postby AZCRXSI » Sun Oct 09, 2011 2:32 am
Its me DUB wrote:Looks great Jeff! Man, you've already got 3 CRXs in here for a mini meet. :P
Nope, you are on... It is a red pin stripe! I want to remove it, but am nervous about what would be left behind.
Yes! It is nice to see some other AZ brothers come out of the woodwork...
AZCRXSI
Postby CoolCrxSiGuy » Sun Oct 09, 2011 8:13 am
Looks perfect the way it is! Very clean, I love the y49's!
90 y-49 CURSED!
CoolCrxSiGuy
Postby AlexCRX » Sun Oct 09, 2011 10:25 am
I'm jealous! :oops:
congrats for the y-49
I hope I'll have one someday!
CDM 91 Si
CDM 91 Si Special Edition mint!
USDM 91 HF
AlexCRX
Postby AZCRXSI » Sun Oct 09, 2011 10:59 am
Thanks for the kind words guys! I'm pretty excited about it!
AZCRXSI
Postby Leon » Sun Oct 09, 2011 12:47 pm
This is one clean rex. :-)b .
Leon
Postby Its me DUB » Sun Oct 09, 2011 1:32 pm
This may be an idea. http://cgi.ebay.com/ebaymotors/Honda-lo ... 2314998680 I've got to do the same as mine is chipped in a few spots.
Or get red wheels. ;)
Its me DUB
Grill Master
Postby daveb91 » Sun Oct 09, 2011 3:20 pm
So you had a CRX and sold to get into MINIs and then bought another CRX.........Dave sold this CRX to you so he could get a Mini. Now that you have bought it do you have anything to say to him?
daveb91
Postby AZCRXSI » Sun Oct 09, 2011 4:26 pm
@Justin
Very nice, did not know these were around... But, be that as it may, I want out of the pin strip world... Dont like it very much...
@Dave
Yes, thank you! but he knows this... I've thanked him profusely for selling me his CRX... :mrgreen: I get it! MINIs are neat cars... I have my MCS for a DD and all the kids fit in it unlike the CRX. But if there is a time where I want to cruise up to Sedona with the boss, we can take the Rex and carve up the canyons. Best of both worlds with have a 2 seater and a 4 seater.
AZCRXSI
Postby Dave_Darling » Mon Oct 10, 2011 7:47 pm
I would leave the pin-stripe; there is significant fading on some of the panels and I'm pretty sure you'd get at least a couple with little stripes of brighter yellow than the rest of the paint. That's one reason I left it on.
Jeff, I'm really glad to see MB in good hands! The pics make me miss him, but I must admit I'm having fun in the MINI.
Daveb, I already knew Jeff's story before I ordered my MINI. I chose to get another car for a variety of reasons, which I won't bother everyone with. The MINI isn't a CRX--I firmly believe that there will NEVER be another CRX--but it is a good car. And it seems to fit what I want now.
--DD
Dave_Darling
Postby vanrij » Mon Oct 10, 2011 9:33 pm
Awesome history on the car. And by the sounds (reads of it?) of it you are keeping the momentum.
Postby logan90crx » Mon Oct 10, 2011 9:53 pm
AZ represent!! lol.
You ever go to the Pavilions meet?
Awesome car man we should meet up sometime!
-Logan
Rio Red 90 Si
$2800
91 Si, SOHC ZC VTEC (stolen)
logan90crx
Postby AZCRXSI » Mon Oct 10, 2011 10:17 pm
@vanrij
Very true! It is neat to have a previous owner and current owner so interested in a single car.
@logan
Yeah! AZ!!! I haven't been to a Pavilions meet in some time... Saturday night, right? Is that or it was an old classic car show by McDonalds... still there?
AZCRXSI
Postby asianflava » Tue Oct 11, 2011 2:30 am
My CRX has a pink and purple pinstripe on it, yes pink and purple. It is an actual painted stripe, not a sticker. I have considered trying to remove it with compound, but I'm afraid I'll damage the paint. I'll just live with it.
91 CRX Si (hers)
89 Civic Si (his)
01 Toyota Highlander (hers)
07 Toyota Tundra (his)
asianflava
Postby nleonard12 » Tue Oct 11, 2011 11:30 am
was wondering what kind of hp stock a y series is and if building one up would be cheaper than building a b series. i looked into building up a d16 but then i realized that oil pump dones have a better version, and them stock oil pumps cant handle a beating
nleonard12
Postby logan90crx » Tue Oct 11, 2011 11:36 am
AZCRXSI wrote:@vanrij
@logan
Yep saturday night, it is the classic car show, but usually around 7-9 is the imports and Honda scene. I haven't been there in a while, PM me if you ever plan on going we will meet up!
-Logan
Rio Red 90 Si
$2800
logan90crx
Users browsing this forum: Google [Bot] and 1 guest
