Ef yu's crx
Re: Ef yu's crx
Postby ef yu » Fri Jun 20, 2014 1:41 am
yeah i can weigh all that for you. probably can do it tomorrow. :-)b
- jim
ef yu
Re: Ef yu's crx
Postby Jzak » Fri Jun 20, 2014 10:39 am
Looking good, I checked your thread to see if you really did pull the entire a/c out and you REALLY DID!
I bet your evap being as dirty as it was has something to do with the a/c not working....
I plan on cleaning/replacing mine this year also.
Good job on the vacuum gauge! with the cleaned injectors and you paying attention to the gauge more you will def see some better mpgs!
1990 HF
Rebuilt D15b6 trying to keep her as stock as possible
Still get 50+ mpgs with over 750,000 miles on her.
Going to take her to 1,000,000 and maybe more!
viewtopic.php?f=26&t=65252&p=689566
"Million Mile CRX"
https://www.facebook.com/millionmilecrx/
Jzak
Re: Ef yu's crx
Postby ef yu » Fri Jun 20, 2014 7:48 pm
@VanriJ, i just weighed everything (dont mind the disassembled compressor, i put everything in the bucket) came out to 34 lbs minus the weight of the container. btw i didnt put in the AC bracket.
also the scale doesn't recognizes the container weight so its about 34lbs minus the weight of the container + the weight of the AC bracket.
Hopefully i didnt forget anything else to add in.
- jim
ef yu
Re: Ef yu's crx
Postby ef yu » Fri Jun 20, 2014 7:54 pm
Jzak wrote:Looking good, I checked your thread to see if you really did pull the entire a/c out and you REALLY DID!
Thanks! yeah the gauge actually helps a lot. especially when i think im going easy on the throttle when actually im not.
hoping i can beat 40mpg soon. its like a never ending goal lol. My gf thinks im crazy that im so obsessed with achieving more MPG. :rofl:
- jim
ef yu
Re: Ef yu's crx
Postby KevinEF7 » Fri Jun 20, 2014 8:04 pm
Good to know thanks for doing that, so about 35 pounds with bracket
KevinEF7
Re: Ef yu's crx
Postby ef yu » Fri Jun 20, 2014 9:50 pm
actually, i take it back. i used our air pump for our camping mattress and blew water out of lines + condenser + evaporator. there was quite a bit of water from me pressure washing everything last night at the car wash, so ill reweigh everything again to get a more accurate weight.
stocking my new parts already. just a new drier + expansion valve.
- jim
ef yu
Re: Ef yu's crx
Postby ef yu » Sat Jun 21, 2014 11:28 pm
alright, blew out any last water i could find. reweighed everything, this time including the ac bracket, it adds up to 36lbs.
so the AC unit adds approximately a total weight of 36lbs.
Also went to my favorite japanese dollar store and found something that i might be able to use when reinstalling my ac components.
going to add these to the vents to help seal the air from escaping the ac box + fan box.
the material seems about the same as oem.
- jim
ef yu
Re: Ef yu's crx
Postby ef yu » Sun Jun 22, 2014 11:01 pm
almost done collecting parts for the re-installation.
- jim
ef yu
Re: Ef yu's crx // road to air conditioning
Postby vanrij » Tue Jun 24, 2014 12:58 am
Nice! Thanks for posting the weight. I have seen numbers posted all they way up to 65lbs lol. Its still a good bit of weight but at this point I would rather take a functional AC. Great work, keep it up. :-)b
Postby ef yu » Mon Jul 21, 2014 7:09 pm
got the ac running yesterday. so pumped about it that the first thing i did when i woke up was used the car to go gym (normally we take my gf's car) showed off the ac coldness however she wasnt impressed. lol
about 4pm today, the crx was toasting inside. took out the digital thermometer (kitchen thermometer, not sure if this works as well as the automotive thermometer)
car was 112 and climbing.
turned on the ac the temperature started dropping quick. about one minute or so into it, it dropped to 62.
it started slowing down so i stepped on the gas pedal and it got down to 55.
drove the crx around town and it got down to 48!! stoked about how cold it gets. extremely happy about it.
guess we wont be needing to take the gf car on long trips anymore!!!
- jim
ef yu
Re: Ef yu's crx // A/C fully working
Postby razordave » Mon Jul 21, 2014 10:36 pm
That a/c post is exciting. I will need to replace everything on my rex, nothing is there, literally.
I did just fix the daily's (my grandfather's 05 silverado) but that was the oh so common blower resistor.
Did you happen to take any photos of anything that was out of the norm? or did it just go like buttah?
razordave
Postby ef yu » Mon Jul 21, 2014 10:41 pm
pretty much everything went in as it should without any hiccups. the only "hard" part was figuring out where/how some of the lines went but even then its not all too bad. i should have taken more pics but was really nervous about the whole thing working.
AC is a must living in souther california! i dont know how some of you rex owners do it in TX or AZ without them!!! :dizzy:
also just installed my new led bulb for my vacuum/boost guage. looks awesome compared to the incandescent bulb.
definitely brighter than my cluster. will swap out the bulbs in the cluster for led later on. easier to read at night and looks cool!
- jim
ef yu
Postby razordave » Tue Jul 22, 2014 12:15 am
Yeah, I'm new to south florida. probably biggest reason the cars living in the garage lol.
AZ is hot! I would not want to be there unless I could work somewhere with an attached air conditioned garage lol
razordave
Postby AZCRXSI » Tue Jul 22, 2014 10:25 am
Great job on the A/C. I can relate to the g/f story. My wife (then g/f) was similar in that the minor victories I was excited about became eyes rolling when I told her. Too funny. Keep up the good work. :-)b
hehe
You do get used to the heat in AZ. There is no humidity which is nice (for the most part). But when it hits 110-115, everyone runs for cover or the pool. And if you are working outside, I imagine that can get brutal.
1990 CRX Si BUILD THREAD
AZCRXSI
Postby razordave » Tue Jul 22, 2014 2:53 pm
My old boss told me when he lived in AZ, they had to heat the pool.. something to do with avoiding cardiac arrest ;)
I've found that ladies couldn't care less about my car.. idk why ;) yours on the other hand.. hey, let's trade so I can get a date haha
razordave
Postby 88sohcrex » Wed Jul 23, 2014 1:36 am
Most girls think my 89 crx si is "cute" :yell: You do NOT call a man's car cute. I nicknamed mine the gokart.
88sohcrex
Postby AZCRXSI » Wed Jul 23, 2014 11:11 am
88sohcrex wrote:Most girls think my 89 crx si is "cute" :yell: You do NOT call a man's car cute. I nicknamed mine the gokart.
haha Good point. :lol:
AZCRXSI
Postby ef yu » Thu Jul 24, 2014 8:35 pm
decided to put in some led since the vac guage was a lot brighter than the whole cluster. took about 30 minutes to clean/replace bulb/ flip the polarity. definitely easier to read at night. but i feel like i've ruined its originality with the leds... anyways here it is.
Need to figure out a way to help brighten the needles. wondering if i should paint the needles in a fluorescent orange to help.
also went to the grocery store later that night and found this note on my window. lol
i've had many people wanting to buy my car for a RIDICULOUS low amount.
- jim
ef yu
Postby ef yu » Thu Jul 24, 2014 10:50 pm
just finished washing and waxing the thing. paint definitely will need some work sometime in the near future. took some pics but damn do i wish i have a better camera. :eatfly:
never really showed my interior. not the best pic but itll do for now.
thinking about lowering the car a bit. probably will try to find some H&R sport springs or some eibach sport springs. if anyone knows who is selling some LMK!
- jim
ef yu
Postby Rex All Day » Sun Jul 27, 2014 12:23 am
love this rex man keep it up!
:-)b :-)b
Black 1991 CRX Si - 1.6 SOHC ZC motor.
Thread: viewtopic.php?f=26&t=62162
Rex All Day
Postby ef yu » Thu Jul 31, 2014 8:45 pm
thanks tim!
bought some plastidip over the weekend. thought id give it a try. forgot which member on here did it and it came out great on the faded out moldings.
close up view
hard to tell form angle/shadow but it definitely looks 10x better. going to do the other side tomorrow and finish it up with the rear.
got carried away and did my fogs
bulbs are burnt out and well, just dont ever feel like using them anyway. probably going to buy some H logo vinyl and place them over the fogs to make it look like fog covers lol. :rofl:
- jim
ef yu
Postby J Wid » Thu Jul 31, 2014 10:12 pm
Good job on that AC rebuild, I love it! I've rebuilt 2 in the past 3 years and it's the best upgrade ever! Car looks good!
J Wid
Postby ef yu » Fri Aug 01, 2014 2:37 pm
finished it up with the driver side and the rear. the moldings makes the car look a lot better. :-)b
- jim
ef yu
Postby Cementups » Sun Aug 03, 2014 9:10 am
give it a bath, Jim. :P
Cementups
Postby ef yu » Sun Aug 03, 2014 1:23 pm
lmao, it just got a natural bath last night so its all good 8)
ill give it a nice buff job before the meet next week.
- jim
ef yu
