1991 CRX SI Build
Re: 1991 CRX SI Build
Postby Chase1Ratliff » Wed Apr 27, 2016 3:41 pm
AZCRXSI wrote:
Chase1Ratliff wrote:
AZCRXSI wrote:Good job!
Pics look good! :-)b
It's been really slow since I've started this post. But it's starting to come along nicely
As long as you are still enjoying it, that is all that matters.
This is a marathon, not a sprint. :-)b
Loving every second of it! My bank account not so much.
I'm hoping to have out for my first track day by the time I'm 22 lmao.
1991 CRX SI- Work in progress
1999 Audi A4 Avant- DD
Build Thread viewtopic.php?f=26&t=69106
Chase1Ratliff
Postby Chase1Ratliff » Mon May 02, 2016 3:52 pm
Just ordered everything to rebuild my steering rack. New bushing and inner/outer tie rods, so hopefully this weekend I can have the rack back together and then I can start throwing the front end back together. One step closer! And I figured I'd show you guys what I did to my daily.
Lowered and some BBS LM reps
Sent from my iPhone using Tapatalk
Chase1Ratliff
Postby Chase1Ratliff » Tue May 24, 2016 2:37 pm
Ready to go to paint! Now to find a shop that won't take a month to do it.
Put a few coats of paint on the transmission!
Before
After
Now to get the engine ready for the same treatment
Chase1Ratliff
Postby Charlie » Wed May 25, 2016 10:07 am
i get so jealous every time i see a white Si being restored... Hopefully i'll be doing this soon!
great job so far! i love seeing every part cleaned and painted/powder coated!
Charlie
Postby Chase1Ratliff » Tue Jun 07, 2016 9:22 am
Charlie wrote:i get so jealous every time i see a white Si being restored... Hopefully i'll be doing this soon!
Thanks man! I get OCD about this stuff. I know nobody will ever see half of it but I know it's there and done right.
Chase1Ratliff
Postby Chase1Ratliff » Fri Jun 24, 2016 12:17 pm
Well that was stressful [emoji23]
Chase1Ratliff
Postby RestorationCRX » Fri Jun 24, 2016 2:19 pm
Fantastic job! Can't wait to see more. Love what you did with the powdercoating on the previous page :-)b
Check out our 1991 Honda CRX Si Restoration
http://www.restorationcrx.com
RestorationCRX
Postby Chase1Ratliff » Fri Jun 24, 2016 9:52 pm
RestorationCRX wrote:Fantastic job! Can't wait to see more. Love what you did with the powdercoating on the previous page :-)b
Thanks my man! It is definitely worth the money to do it! A lot went on today, a head gasket and timing belt job turned into a full rebuild. When we took apart on of the Pistons was seized (side to side motion, not up and down) so figure the rings were locked up. And we were right 2 Pistons had locked oil rings. Other one all of them were. Not damage to the walls thankfully.
Kitty worked to hard so she needed a nap [emoji23] (the garage needs a major cleaning)
Chase1Ratliff
Postby Chase1Ratliff » Fri Aug 05, 2016 2:05 pm
A few updates but no pictures. Sorry! Car is still at the paint shop, I have no idea when it will be done(a few months now for just a engine bay). Also heard back from the machine shop the Z6 needs bored out so here's where I need some guidance. Should I do a NA build with the Z6 or buy a B16 and be get it over with? If I were to do a mild NA build I'd go:
PG6 pistons
Stock rods(need to do research and maybe get better ones)
Skunk 2 Intake Mani (Have already)
Skunk 2 TB I think they are 68MM
Stock Head(unless it fails pressure testing)
I don't wanna go all out on a D series build unless I was going FI. Which I don't think that's the way I wanna go.
Chase1Ratliff
Postby ef yu » Fri Aug 05, 2016 3:01 pm
I can tell you from experience that a b16 "feels" heavier up front than a d16. however, the b16 feels EXACTLY like the D16 from 1k-5k rpm. The only fun part with a B16 is pass 5k and ask yourself, how many times in a day do you go pass that?
I was in a similar dilemma, where i could go b series and call it done but instead i stuck with a D series and did all motor. high comp, bored .20 over, lighten flywheel/pulley, high-rate valve springs, and a mild weber cam shaft. Of all that money i spent on it, i could have gotten a pretty gsr for it but i stuck with the idea of when/if i beat other people with a SOHC id get the face " :yuck: ". none the less, it didnt work out, the A6 could only go so much before it detonated (no tune).
In the end, i bought a B16 + S1 cable trans and never looked back into a d-series.
- jim
ef yu
1991 CRX SI Build
Postby Chase1Ratliff » Fri Aug 05, 2016 4:45 pm
ef yu wrote:I can tell you from experience that a b16 "feels" heavier up front than a d16. however, the b16 feels EXACTLY like the D16 from 1k-5k rpm. The only fun part with a B16 is pass 5k and ask yourself, how many times in a day do you go pass that?
After looking at some prices I will stick to the NA build.
• PG6 Pistons (have)
• Stock Connecting Rods resized for ARP bolts
• ARP rod bolts (have)
• Stock head unless it fails
• All new OEM gaskets (have most)
• OEM oil pump, water pump, etc (have most)
• Timing belt (have)
• Skunk 2 Intake+TB (need the TB)
• CAI of some sort (may go with stock because I love the way they look in a tucked bay)
• DC 4-2-1 Header (have)
• R&D exhaust (have)
• OBD1 injectors to be done with the OBD1 swap
• Tuned on crome
• Hasport Mounts
Chase1Ratliff
Postby Chase1Ratliff » Mon Aug 08, 2016 6:16 pm
Picked these up for $120 locally! A set of 75.5mm PG6 pistons, got lucky on finding these. Image
A set of coaster AFH sent me with an order awhile back, peep that perfect climate control I picked up for $100!
Chase1Ratliff
Postby L8BRAKER427 » Wed Aug 10, 2016 9:38 am
Looks good man. Doing a lot of the same work on mine
L8BRAKER427
Postby Chase1Ratliff » Wed Aug 10, 2016 10:52 am
L8BRAKER427 wrote:Looks good man. Doing a lot of the same work on mine
Good luck on it all! I should have the car back in the next few weeks, dropping stuff off this Friday to the machine shop to get that all done so I can put my engine back together. The plan is to abuse this motor at the track/Autocross/Touge runs etc. Then it'll be time to put on my big boy pants and go B or K series [emoji848]
Chase1Ratliff
Postby Chase1Ratliff » Mon Aug 22, 2016 5:11 pm
I try to wait to do big updates but I just get to excited to share my progress with you guys!
First I got my engine back from the machine shop
Then I proceeded to throw some engine paint on it to make it look better
As I was driving to pick up some papers form work my buddy who works at the body shop where my car is sends me this!
You can definitely say that I'm pretty excited!! [emoji16]. Will be ordering everything to rebuild my engine soon, I just got laid off from work and am drawing low income until work picks back up.
Chase1Ratliff
Postby Chase1Ratliff » Fri Sep 16, 2016 11:41 pm
Little update for you guys. Just ordered everything to rebuild my engine. Progress has been slow, still a lot of little things to do that's taking me forever. Here is some progress pics.
Finally back in the garage!
Suspension all put back together and looking pretty
Here it sits as if right now.
And decided to spruce up the Intake manifold I bought, I took this picture right after I dropped it lol. I have repainted it so there is no chips
On a side note I'm really digging the downstar bolts
That's everything for now really. Engine should be put back together in a week when I get my parts in.
Chase1Ratliff
Postby umop3plsdn3dlus » Mon Sep 26, 2016 11:09 am
It's looking good! Can't wait to see it completed :-)b
Dustin - Central Texas
umop3plsdn3dlus
Postby Chase1Ratliff » Tue Dec 06, 2016 7:53 pm
Finally an update! I'm pretty excited to get her back on the ground in the next week or two. Well then it's time for the rear to be put up and everything rebuilt back there. Anyways here's some pictures,
First I installed my innovative traction bar
Then rebuilt my calipers and was able to throw my rotors and pads on
I am running Hawk HPS pads and Brake performance rotors. They come with a coating to protect the non contact parts from rusting. I've been running them on my Audi for over a year and not one spot of rust has showed up on them, they sell every type of rotor (slotted,dimpled,drilled) so go check them out!
Chase1Ratliff
Previous
