trying to I D this engine
Postby jzxcrx » Fri Aug 19, 2016 1:08 pm
D15B
1457755
Pretty sure its a replacement engine in my 91HF.
With my search, "D15B" I come up with various possibilities. Can I narrow it down somehow?
Thanks
jzxcrx
Re: trying to I D this engine
Postby 94eg! » Fri Aug 19, 2016 1:49 pm
Probably a JDM import. They usually have only a 4-digit block code.
94eg!
Postby jfrolang » Fri Aug 19, 2016 3:17 pm
jzxcrx wrote:Can I narrow it down somehow?
Post a pic.
Postby jzxcrx » Fri Aug 19, 2016 6:33 pm
Whoo. Gotta brush up on posting pictures.
Yeah, my searching is coming up with ''V-tec" or non V-tec for this engine with the block number.
Could have something to do with which head it has on it? I really don't know s**t about these engines.
Here is the before/after of the VC repaint. Stripped it and used Duplicolor Engine Enamel which is my standby spraycan paint for a lot of automotive stuff.
jzxcrx
Postby jfrolang » Mon Aug 22, 2016 3:17 am
Assuming the engine was used as a longblock replacement, it's just an 88-91 D15 non-VTEC. Probably the closest approximation would be a D15B2. For whatever reason Honda only used the 4-digit codes in Japan, so D15B got stamped on many different engines over there. The manifolds are original to your HF.
If you look at the head code (PM3, PM8, etc) you'll be able to narrow it down further. But I would not suspect anything special. It's possible that only the shortblock was swapped and the HF head was retained, but that almost never happens.
Postby jzxcrx » Mon Aug 22, 2016 11:57 pm
Okay, thanks. I was looking at this list
viewtopic.php?t=5784
to find out more about it, but what's the h.p. for it? 92 or 130 ??
jzxcrx
Postby jfrolang » Tue Aug 23, 2016 12:28 pm
For that engine in its original configuration, probably about 92.
In your car considering the HF manifolds, about 60.
Postby jlicrx » Tue Aug 23, 2016 3:28 pm
jfrolang wrote:For that engine in its original configuration, probably about 92.
I would guess it at a little more if it has the PM3 16 valve head - maybe about 75-80 - probably not more than that - could also depend on the ECU - what ECU are you running? PM-8?
ZCspeed Racing
jlicrx
Postby msc » Tue Aug 23, 2016 4:48 pm
Is it an 8 or 16 valve head? If it's a short block swap rather then a long block swap I would expect low compression unless the builder knew to CC the head and shave as necessary to set the compression ratio to stock or higher.
If the Injectors are not properly paired with the ECU that could cause poor running issues.
If this is a long block swap with all other parts left alone I would expect slightly more then stock HF peek HP with a slight loss in low end torque. Performance would also be dependent on what transmission you have. If you have the stock HF transmission you might get slighter higher MPG in 4th gear rather then 5th.
Mike
msc
Postby jzxcrx » Thu May 18, 2017 11:52 pm
..back to this,..
So the stamp on my engine is D15B,
and Im looking at chart like this;
http://hondaswap.com/threads/honda-engine-list.29128/
and it says 130 hp @ 3800 rpm for listed "D15B".
Anyway, car does seem to have some horsepower, and some torque. It is a replacement engine.
jzxcrx
Postby jlicrx » Fri May 19, 2017 9:03 am
the 130hp D15B is the VTEC version - yours is not the VTEC version, therefore not 130hp
ZCspeed Racing
jlicrx
Postby jzxcrx » Fri May 19, 2017 7:48 pm
What version is it ?
Maybe I'm thinking too literally about referencing my engine to these lists and charts.
jzxcrx
Postby Mista Bone » Sat May 20, 2017 4:54 am
D15B7 would be the closest, 102 chp
Imagine a D15B2 with a D16A6 MPFI swap, which is what you have.
20 years later, I might be repeating the D15Beast...I've got some old parts laying around.
Postby jlicrx » Sat May 20, 2017 12:37 pm
jzxcrx wrote:What version is it ?
as far as I have been able to determine, all of the non-VTEC JDM D15B engines had carbs, either single or dual - we have swapped many of these over the years and have never seen a single carb model - all of these carbed D15B engines were around 100 hp (91 for the single carb) - my guess would be that your JDM D15B was a dual carb model, which single or dual doesn't really make any difference since the original D15B6 intake manifold from the HF was swapped onto the JDM D15B - I would also guess that the HF PM8 eight valve head was not swapped onto the D15B as the resulting very low compression ratio for that combination wouldn't produce much power - the original carbed engine used a mechanical fuel pump which was actuated by an additional lobe on the camshaft - the pump was located on the back of the head near the distributor end just in front of the EGR valve - if the engine currently has the PM3 sixteen valve head that came on the D15B, you should be able to see a block-off plate, which someone had to fabricate and install where the fuel pump was removed, like the one in the attached picture - I would assume you are running it with the original HF ECU which was the PM-8? - otherwise you would be getting a check engine light and a code 12 for the EGR valve - with the relatively small intake manifold and small throttle body from the HF along with the PM-8 ECU, I would guess the hp would be around 90, if that.
ZCspeed Racing
jlicrx
Postby jzxcrx » Sat May 20, 2017 1:05 pm
That's something. Thanks for the input.
jzxcrx
Users browsing this forum: No registered users and 5 guests
