does a catalytic converter make noises
Postby blkjak » Sat Oct 11, 2008 3:02 pm
hi -
does a catalytic converter make weird noises when it heats up and is going bad?
what does it sound like?
i t has 150,000 miles on it -
blkjak - thanks
88 dx hatch-first
94 dx hatch-second
89 dx crx coupe-last
blkjak
Postby RamaCrx » Sat Oct 11, 2008 4:38 pm
I've seen them when they start coming apart and all the stuff is loose inside and rattles and or comes out tailpipe.
RamaCrx
Postby 87TransAmGTA » Sat Oct 11, 2008 5:24 pm
attempt to get under the car hit the cat with ur fist or rubber mallet. if theres a small rattle noise coming from it its starting to fall apart inside. but at 150,000 miles its probly in need of replacement soon anyways.
~Kyle
87TransAmGTA
Postby blkjak » Sun Oct 12, 2008 4:48 am
hi -
thanks for the info....i am hearing like a "grrrr" noise when engine at full temp.... can not hear it with hood open....just sitting in driver seat?
blkjak - :?:
88 dx hatch-first
94 dx hatch-second
blkjak
Postby 87TransAmGTA » Sun Oct 12, 2008 7:41 am
possible exhaust leak? tough to say tho.
~Kyle
87TransAmGTA
Postby SETI20 » Sun Oct 12, 2008 8:01 am
150K on a cat? Yeah, it's time for a new one haha.
Service manual specifies you should replace this every 4 years or so.
SETI20
Postby mossin_90 » Sun Oct 12, 2008 6:23 pm
when they are clogged up
smells like a rotten egg
they turn cherry red when hot
the engine sound the same as when the spark plugs are fouled by excess gasoline dumped in the piston chambers.
pull it out and look toward a bright light through the cat hole, the lesser light you see the higher concentration of crap is inside of it, which = time to replace. but at 150 i would replace anyways
'90 CRX DX_5sp
mossin_90
Postby NozHayr » Sun Oct 12, 2008 10:28 pm
Sounds like that pesky input shaft bearing to me.
Far as the cat goes, you don't have emission testing in FL. right? So what the heck, headers and a straight pipe... YEEEE_HAWW!!
:D
NozHayr
Postby blkjak » Mon Oct 13, 2008 3:08 am
NozHayr wrote:Sounds like that pesky input shaft bearing to me.
:D
automatic trans.... :?:
88 dx hatch-first
94 dx hatch-second
blkjak
Users browsing this forum: Google [Bot] and 4 guests
