Crack in transmission
Postby TPhilly » Sat Jan 21, 2017 11:47 pm
I was about to disconnect this shift lever torque rod, and noticed this crack that I circled in this image (it's a bit messy, but that's not what I'm worried about here):
Is there any way I can fix this without replacing (at least) the entire transmission housing? Other than welding it? I didn't remove the rod because I was worried I'd break it in some way I can't fix right now. I can see that it's bolted to that broken piece, but I'm guessing it's got at least a couple bolts attaching it to the transmission or it would just be hanging there.
Or could I just leave this as is?
TPhilly
Re: Crack in transmission
Postby crocrx » Mon Jan 23, 2017 12:38 pm
Replace it, it's cheap.
crocrx
Postby Mista Bone » Mon Jan 23, 2017 5:42 pm
Case needs replaced, likely no fluid in the trans.
With the case replacement you will need to shim the diff and mainshaft, so not a drop in swap.
If that an HF car?
Your location, I'm in Cincinnati, OH.
BoneSpec Transmission
"D" Tranny guru
Mista Bone
Postby TPhilly » Mon Jan 23, 2017 10:32 pm
It's a DX. So you think it's not just the mounting surface for that rod that's cracked, that it's cracked through and that's what's causing all that crud? I guess I could find out for sure if I added some fluid. Also I guess I don't understand why it couldn't just be a drop in replacement.
Sorry if I'm asking silly questions, this is all mostly new to me. And I'm in central Arkansas.
TPhilly
Postby Mista Bone » Tue Jan 24, 2017 12:38 am
oil leak attracting the dust and grit IMHO.
You could drop in another rebuilt trans, or fix your case issue and do a normal go through while the guts are swapped into another case.
Being a 35mm DX case I should have a few extra laying around. On these 88-91 cases the shifter forks are no longer available, hence why I have been robbing them from perfectly good DX and HF cases.
I think I have 10-12 cases laying around with missing shifter fork assemblies because of this.
"D" Tranny guru
Mista Bone
Postby TPhilly » Fri Jan 27, 2017 2:55 am
So if I swap everything into another case, which cases will work? Just 88-91 DX? Or all 88-91 CRX? What about a case from a regular Civic?
I don't really see this happening any time soon, but still would like to know what to be looking for.
TPhilly
Postby Mista Bone » Fri Jan 27, 2017 6:36 am
PL3-A000 or PL3-A100 case, DX/LX/EX/HF, not Si.
PS: I'm the person who cracked the case code over 15 years ago.
"D" Tranny guru
Mista Bone
Postby TPhilly » Fri Jan 27, 2017 10:53 am
All right. Thanks for the info.
TPhilly
