90 CRX SI steering knuckle to a 90 CRX HF
Postby pyropete » Wed Feb 15, 2017 12:23 pm
I have a 90 CRX HF with a bent (LH) steering knuckle. Does anyone know if I can install a 90 CRX SI steering knuckle on my HF? The Honda part numbers are not the same (SI knuckle verses the HF knuckle). The HF part number is (LH)- 51215-SH2-AO1 - The SI part number is (LH) - 51215-SH3-O3O Any help will be greatly appreciated. Thanks Pete
pyropete
Re: 90 CRX SI steering knuckle to a 90 CRX HF
Postby jfrolang » Wed Feb 15, 2017 4:33 pm
I can tell you that the hubs are not the same. The axle you have won't fit in the Si hub. Are you willing to swap axles? That also means new trans oil.
The brakes are different as well but can be swapped.
Postby Myriad » Thu Feb 16, 2017 1:14 am
Couldn't you just have HF hubs pressed into Si knuckles?
Postby jfrolang » Thu Feb 16, 2017 3:21 am
Yes,if you have a new bearing, access to a press, and assuming the diameters are compatible. I haven't compared them closely enough to say that the hubs and/or bearings can be swapped. Maybe someone else knows better.
Postby Myriad » Wed Feb 22, 2017 12:48 am
I just had a local shop do those jobs for $20; though, I admit it can get expensive if you need multiple hubs pressed.
Users browsing this forum: Bing [Bot] and 1 guest
