I need some help with my 1G not running.
Postby mavrik8511 » Fri Mar 03, 2017 12:04 pm
I just picked up a completely unmolested 1987 DX (auto, carb) and I am having some problems with keeping it running. It will start right away, and with the choke on will stay at about 2800rpm (most of the time). As soon as the choke goes off it will choke and die. I can restart it and physically keep it at 2000rpm without a problem. As soon as I let off the gas, it dies. I thought his would be a vacuum leak problem but I cannot seem to find a leak anywhere. I sprayed carb cleaner everywhere I could reach with no discernable difference. The only thing that stands out to me is that the PCV hose collapses completely with the engine running. Could this be a problem? How would I verify that I am not having an issue with the carb insulator?
Any help is appreciated.
Maverick
mavrik8511
Postby Myriad » Sat Mar 04, 2017 9:22 am
It should just be your idle screw. It's a massive one that will move the throttle valve when turned. Turn it in a bunch until the throttle is visibly open, turn the car on, and back off the screw until it idles nicely.
All with your air filter housing off, of course.
Myriad
Users browsing this forum: Bing [Bot] and 4 guests
