Is there a reason to replace bushings?
Postby thegregmitchell » Mon Mar 20, 2017 7:56 pm
I have a 91 crx DX that just reached 100,000 miles. The steering isn't super crisp and it's running all weather tires. Should I be looking into replacing bushings to help restore that "out of the box" steering response?
thegregmitchell
Re: Is there a reason to replace bushings?
Postby jfrolang » Mon Mar 20, 2017 9:02 pm
Inspect the bushings first. But I suspect original, 26+ year old bushings would be due for replacement by now regardless of mileage. Take a look at the ball joints too and check for leaks or play.
jfrolang
Site Admin
Postby raffaelli » Wed Mar 22, 2017 7:13 am
Worn inner tie rods can also help make the steering lazy.
raffaelli
