Pulling the tranny
Pulling the tranny
Postby jzxcrx » Fri Apr 14, 2017 1:21 pm
So my latest CRX is going to be a bigger project than I hoped. 91 HF.
I've got to remove transmission to fix the bad input shaft bearing.
Haven't really worked on Hondas to any extent, ..easy, right?
So I'm gonna remove the transmission from UNDER the car? I don't have a lift. Any tips or advice appreciated, also
Is there any how-to threads on this board for dropping the tranny. I've been looking through the searches.
When I get the tranny out am I going to replace the input shaft bearing myself?
All I'll need for special tools is an inside puller for the bearing?
(Or should I start thinking about paying the $700 thetranny shop wants to "rebuild" the transmission - IF I deliver it to them).
Thanks folks.
jzxcrx
Re: Pulling the tranny
Postby 4drSpankR » Fri Apr 14, 2017 2:59 pm
http://crxcommunity.com/viewtopic.php?t=51949 (Stock garage FAQ)
It's fairly simple getting the trans out on one of these small cars. I did the same job as you on my '91HF, ISB was bad as well. Take the trans out yourself, and take it to the shop, all they need to do is replace the ISB and that is no where near the $700 range.
4drSpankR
Postby Mista Bone » Sat Apr 15, 2017 5:42 pm
jzxcrx, where are you located?
If I'm close enough, I'm your cheapest option.
BoneSpec Transmission
"D" Tranny guru
Mista Bone
Postby jzxcrx » Sat Apr 15, 2017 10:59 pm
Yeah I'm in WA state.
Quote I got from transmission shop was for hours and hours of labor :twisted:
SAME OLD S**T. Do it yourself.
jzxcrx
Postby 4drSpankR » Sun Apr 16, 2017 8:19 am
jzxcrx wrote:Quote I got from transmission shop was for hours and hours of labor
You could have that motor out in 1-2 hours. Definitely do it yourself. These are one of the easiest cars to work on.
4drSpankR
Postby jzxcrx » Sun Apr 16, 2017 2:03 pm
Thanks. I've gotten myself the factory service manual off eBay so that's good.
So do Ihave to pull the whole engine, or can I get it out from underneath?
jzxcrx
Postby kracksmith » Sun Apr 16, 2017 9:47 pm
when mechanic change the clutch or replace the rear main seal, they just are able to remove the tranny alone without removing the entire engine. it would be nice to remove the entire engine and do some gasket and senor replacements.
kracksmith
Postby raffaelli » Mon Apr 17, 2017 10:23 am
It takes about an hour or so to get the transmission out. The hardest part about it is gettting the bitch pin out.
I make a cardboard template of the mating surface. I use it to get track of what bolts go where and what direction. You do not want to get that wrong.
raffaelli
