I lost one of the little bastards (the little rubber stops on the cargo cover that are held on by screws with heads that just cover the hole in the rubber that they go through), and can't find it in the rear hatch area, so it probably escaped. :doh:
Has anyone found done a McGuyver on this with non-oem parts that's worked? My cover has the typical separation but not too bad so I don't want to spend $150-200 on a new one just for the little bumpstop. Otherwise, I guess I'll just go to Home Depot and see what I can find, but if someone has already gone through this, I'm all ears. Gracias.
