86 CRX Choke Help
86 CRX Choke Help
Postby Jordanjk123 » Wed Apr 26, 2017 12:55 pm
Hello,
Just picked up an 86 crx about a week ago. It will only start if i pump the gas pedal and then hold it for a minute or two, otherwise it just dies. When i press the gas pedal the choke barely opens, is this what is causing it not to start and idle correctly? do i need to replace/adjust the choke? The adjustment plate appears to be riveted in place. Thanks your help.
Jordanjk123
