Parasitic drain finally solved - thanks msc
Postby jzxcrx » Thu Apr 27, 2017 11:32 am
Went through all the searches on here to figure out why battery was draining on the 91 HF.
Seatbelt light staying on in the cluster, and I opened up the driver side door card to disconnect the door switch connector.
Long story short, I had to do BOTH doors.
of course when I opened them up I had to clean and refurb the plastic moisture barrier etc. Like 4-times the amount of work!
Thanks msc for repeating the fix solution on here over and over for the benefit of us guys.
It's nice to get rid of that problem and not see those dash lights anymore.
jzxcrx
Re: Parasitic drain finally solved - thanks msc
Postby Myriad » Sat Apr 29, 2017 11:07 am
I still want to see the fix sticky-d.
Myriad
Users browsing this forum: Bing [Bot], Majestic-12 [Bot] and 1 guest
