Two way valve question
Postby 91ghoststripes » Sat Apr 29, 2017 6:02 pm
I have a 91 crx and I recently replaced the gas tank and upgraded the fuel pump. However, the fuel lines and something the parts diagram calls a two way valve are aging poorly. I am looking for ideas on how to replace or eliminate this part. And any good ideas on going aftermarket on replacement fuel lines since oem are no longer available.
91ghoststripes
