A/C removal question
Postby Tasos_7R » Mon May 01, 2017 3:07 am
Hi guys,
I'm removing my A/C system from my VT and i'm not sure where to plug the radiator fan, since the plug was on the A/C loom. I made a quick sketch to show you what i mean:
I'm removing the whole A/C loom so, should i plug the yellow male plug that's on the headlight loom on to the green female plug on the the radiator fan??? Also on the A/C loom there are 3 relays. Are they all for the A/C or one of them is for the radiator fan??? Should i make a new loom to connect the radiator fan???
Thanks,
Tasos
Frost White CRX 1.6i-VT EE8
Tasos_7R
Re: A/C removal question
Postby Tasos_7R » Wed May 03, 2017 1:52 am
No one knows??
Tasos_7R
Postby mossin_90 » Wed May 03, 2017 1:32 pm
plug both fans back, now remove coolant temp sensor(by thermostat. its 2 wires), jump the plug and start the car. whichever fan is spinning that is your radiator cooling fan.
make sure fuses are good and fan are good as well and connected.
if they don't start make sure you are using the right harness. there is a a plug by the driver side headlight conected to one fan as well. iirc
'90 CRX DX_5sp
mossin_90
Postby Tasos_7R » Sat May 06, 2017 2:59 pm
Thanks, i worked it out.
Tasos_7R
Postby mossin_90 » Sun May 07, 2017 8:22 pm
:-)b
as you may have already noticed trafic here has gone down. IIRC its all because of facebook. lots of people joining in.
'90 CRX DX_5sp
mossin_90
Postby Tasos_7R » Sun May 07, 2017 11:37 pm
Yes this happens to many forums. And since i'm not a facebook fan, i don't have a page.
Tasos_7R
