Torsion Bars
Torsion Bars
Postby mholeshot » Mon May 01, 2017 8:18 am
1985 CRX Si. Suggestions for replacement torsion bars?
mholeshot
Re: Torsion Bars
Postby jlicrx » Mon May 01, 2017 8:34 am
from Red Pepper Racing:
Both the Si CRX and DX CRX had the same suspension Specs
Stock 84-87 SI & DX:
Front sway bar 16mm
Torsion bar 20mm @24.5" Long
Civic Wagon 2WD:
Front sway bar 20mm
Torsion bar 21mm @ 22.5"Long (shorter then CRX bar, need wagon torque tubes)
Civic Wagon 4WD:
Torsion Bars 21mm @ 24.75" Long (will work with CRX Torque tubes.)
ZCspeed Racing
jlicrx
