ELD error code
ELD error code
Postby THEirltfg » Mon May 01, 2017 11:36 pm
My check engine light was on and I hooked up my computer to it to see what the code was. It was throwing the ELD error. I have a 90 CRX JDM B16A swapped with a P28 ECU. I've been looking around for answers and have a few things I'm going to try. I'm going to check the alternator and starter connections tomorrow just to make sure nothing is loose. From what I've gathered though is that I may be getting the error because I have a JDM engine with a USDM ECU. I think I've read that only USDM cars have ELD so since I have a JDM engine it doesn't have ELD.
Any suggestions or does that sound correct on why it could possibly be throwing that error?
THEirltfg
Re: ELD error code
Postby ModifiedEF » Tue May 02, 2017 4:14 am
p28 with stock b16a1 map right?
its common problem- don't worry your alternator if everything was ok before.
yes thats could be a problem but you can socket your p28 and get a basemap with eld diasbled.
ModifiedEF
Re: ELD error code
Postby THEirltfg » Tue May 02, 2017 6:49 am
ModifiedEF wrote:p28 with stock b16a1 map right?
Chipped p28 obd1 with JDM b16a. The ones that came in the SIR. So if I just disable it everything will still be fine?
THEirltfg
Re: ELD error code
Postby ModifiedEF » Tue May 02, 2017 7:34 am
yes ll be fine.
ModifiedEF
