ID my transmission?
ID my transmission?
Postby jzxcrx » Thu May 18, 2017 12:00 pm
I'm looking at buying 2 used transmissions supposed to be for HF CRX.
Is there a way to I.d. Them according to the number tag?
L3-1063418
L3-2487997
If they are cheap enough I'm going to practice rebuilding one or both for my '91 HF.
jzxcrx
Re: ID my transmission?
Postby Baker » Thu May 18, 2017 12:49 pm
Asked and aswered....
Check the transmission section...
viewtopic.php?f=3&t=6069
Postby Mista Bone » Thu May 18, 2017 8:25 pm
$50 each for unknown transmissions.
One is 88-early 89, other is 90-91
What are the casting codes?
BoneSpec Transmission
"D" Tranny guru
Mista Bone
Postby jzxcrx » Tue May 23, 2017 10:27 am
Ok, seller gave me casting codes;
One is PL3/A000
other one is PL3/A100
jzxcrx
Postby Baker » Tue May 23, 2017 12:08 pm
jzxcrx wrote:Ok, seller gave me casting codes;
One is PL3/A000
viewtopic.php?t=18130
Postby Mista Bone » Wed May 24, 2017 1:03 am
Both are small 35mm cases, so could be DX, EX or HF.
About 20 years ago I figured out the casting codes after getting a few what was thought to be Si cases which were really DX cases.
"D" Tranny guru
Mista Bone
Postby msc » Wed May 24, 2017 7:32 am
Your going to need to put it in gear and compare the input shaft turns to differential turns. See this thread for details. viewtopic.php?t=246
Mike
msc
Postby jzxcrx » Wed May 24, 2017 11:25 am
msc wrote:Your going to need to put it in gear and compare the input shaft turns to differential turns. See this thread for details. http://crxcommunity.com/viewtopic.php?t=246
Mike
Thanks. I get it now.
jzxcrx
