Hi all,
This has been discussed before, but I am totally stumped!
Here's the issue: Turn the dimmer switch to low-beam: running and tail lights turn on, but the head lights do not. Turn on the hi-beams, all functions are normal and the hi-beam bulbs light.
When I purchased the car, they had very awful cheap "projector" style aftermarket headlights. Unfortunately, I didn't test them before I pulled them and replaced them with DEPO OEM style headlights.
There was a wire connecting the R and L low-beam positive wire together.. I imagine this is because one of the positive leads is bad? Either way, I removed it, re-wired everything back to stock, and the low-beams will not work.
Here's what I've done so far to trouble shoot:
-New dimmer switch was installed
-All new fuses
-New plugs for the headlights (they needed it regarless)
-checked the grounds near each headlight... they appear to be in good condition.
-New Bulbs
The lights STILL won't work!
Do I have a bad ground? Anyone have advise where to look or what else to trouble-shoot?
Any help is appreciated.
-All new fuses
-New Bulbs
