Shifter rod gets pretty hot
Postby NerdCore314 » Wed Sep 28, 2011 10:51 pm
I tried to google this but all that came up was people whining about their metal shift knob getting too hot to touch during the day :?
My question is.... I took the old shift boot off of my crx because it was trash, I gotta get a new one. Anyways, when I shift I usually put my hand on the shifter rod (or whatever you call it) that holds the shift knob and it gets pretty hot? Not unbearably hot but pretty warm, I didnt know if that was normal, a sign of trans problems, or because the shifter bushings (or whatever) are shot?
Weird but anyone have any ideas?
1989 CRX Si (Stolen)
1989 Maxima (Sold)
1988 Fiero Formula (Crashed)
2000 Neon (Traded in)
1997 Accord LX (Caught Fire)
1997 Civic (Traded for second CRX)
1988 CRX Si (Sold)
2005 Scion xA <--- Current Car
NerdCore314
Re: Shifter rod gets pretty hot
Postby THATREDCRX » Wed Sep 28, 2011 11:11 pm
Your exhaust is using it as a heat sink :-)b
THATREDCRX
TERMINATED
Postby Mista Bone » Wed Sep 28, 2011 11:20 pm
which is why the O-rings die over time.
BoneSpec Transmission
"D" Tranny guru
Mista Bone
Postby NerdCore314 » Wed Sep 28, 2011 11:38 pm
Oh, well thats perfectly fine as long as its normal and not causing damage. Thank you guys, make me feel a little better
1989 Maxima (Sold)
1988 CRX Si (Sold)
NerdCore314
Postby NerdCore314 » Tue Nov 15, 2011 1:51 am
Took the rex to the shop and they raised it up on the lift and noticed the resignator (or whatever its called) was right on the bottom of the shifter arm. Which is why my shifting was so rough and what caused the shifter to get so hot (like you said, it was using it as a heat sink) so he got a crow bar and pushed the exhaust about an inch away from the shifter bar, fixing that heating up issue, the rough shifting and the loud rattling it was making.
1989 Maxima (Sold)
1988 CRX Si (Sold)
NerdCore314
Users browsing this forum: Google Adsense [Bot] and 2 guests
