88-91 USDM Crx Differences
Re: 88-91 USDM Crx Differences
Postby tyson » Thu Feb 23, 2012 2:10 pm
whited wrote:I do not agree with the 89 transmission spline is different from the 88. I think the 88-89 has one spline and the 90+ has a different.
you can disagree. you can be wrong too.
tyson
Postby hacksparrow » Mon Mar 19, 2012 10:07 am
whited wrote:89-91 Si seats have pockets on the back of them, 88 seats do not.
not only do i agree with tyson. i have an 88 with 21 teeth, just recently changed the clutch too. it is indeed different from all the E wishbone civics ive ever seen
88 HF-koni str,sportline,F7 LCA,neuspeed strut bars,sol blades 175/70/13
hacksparrow
Postby KrisM » Tue May 29, 2012 3:37 pm
I'm sure this has been corrected already, but 90 to 91 HF's have a 10.6 gallon tank, which is 9.9 Imperial gallons.
1990 Honda CRX HF - ZC SOHC 1.6L non-VTEC, Si trans, Illuminas, Neuspeed Race Springs
Current Mods: Skunk2 TB, Skunk2 IM, ST front and rear Anti-roll bars, Rear LCA's, camber kit
KrisM
Postby Baker » Wed May 30, 2012 7:12 am
KrisM wrote:I'm sure this has been corrected already, but 90 to 91 HF's have a 10.6 gallon tank, which is 9.9 Imperial gallons.
Original post corrected, per 1990 Owners manual, 10.6 US gal / 8.8 Imperial gal.
Postby Tony ED8 » Wed Jun 13, 2012 9:55 pm
Thanks dude this helps a bunch. Do you know how/where i can get OEM interior parts like Climate Control and the center dash piece :?:
91 Civic 4Dr D15B R.I.P | 96 Vw Jetta Vr6 Trashed | 91 Crx Dx D15B My DD
YouTube.com/LsvEF
Tony ED8
Postby Baker » Thu Jun 14, 2012 6:53 am
Tony ED8 wrote: Do you know how/where i can get OEM interior parts like Climate Control and the center dash piece :?:
Classifieds forum on here or
viewtopic.php?f=10&t=12192
Postby Tony ED8 » Fri Jun 15, 2012 6:49 pm
Thanks
YouTube.com/LsvEF
Tony ED8
Postby KevinEF7 » Thu Jun 28, 2012 12:08 pm
What a beautiful thread
Thank you for compiling it, will definetely be coming back to this one many times
KevinEF7
Re: I only knew of two models in the CRX line
Postby Jdat01 » Thu Jun 28, 2012 1:37 pm
jimwww wrote:I only knew that there was a model that was an HF (knew I did not have that) and the SI - I have never heard of a DX before - I thought that was only in the Civic hatchback. Unfortunately any place I have gone to about CRX's do not have a great FAQ and specifications list on the car. Most forums have that.
Like this:
http://jeepforum.com/forum/showthread.php?t=39873
I have not even found a list of what all the engine codes mean.. this b engine etc.
It has been 18 years since I test drove the car and I have never owned one before. I have never seen a designation on the car say DX either.
Anyway.. thanks for the info - now I know.
I know this was from a while ago but I found a forum with the engine codes in case anybody else is having problems
http://crxcommunity.com/viewtopic.php?t=5784
Crx DX 1991
Jdat01
Postby ClassicRex71 » Wed Jul 04, 2012 5:31 pm
Do 89 Si door panels fit into a 91 HF?
ClassicRex71
Postby Baker » Mon Jul 09, 2012 8:29 am
ClassicRex71 wrote:Do 89 Si door panels fit into a 91 HF?
Yes.
viewtopic.php?f=3&t=40532
You match the door panel to the seat belt style.
Postby God Eater » Mon Jul 09, 2012 10:06 am
So.. DX = STD = Standard = Base? :blah:
God Eater
Postby Baker » Mon Jul 09, 2012 10:19 am
God Eater wrote:So.. DX = STD = Standard = Base? :blah:
Read the info, decide for yourself.
It's definitely not the top of the line.
Postby God Eater » Mon Jul 09, 2012 3:09 pm
"Top of the line" is more of an opinion than a fact.
God Eater
Postby Baker » Tue Jul 10, 2012 6:45 am
God Eater wrote:"Top of the line" is more of an opinion than a fact.
"Top of the line" defined as, the best (most expensive) in a given line of merchandise or brand of vehicles sold by a manufacturer, usually within a range of models, which can differ in sizes, capabilities or available options.
Honda marketed and manufactured the Si to be the most expensive and include the most options, hence falling right in line with the definition.
:shrug:
Postby tparsons08 » Fri Jul 20, 2012 12:37 pm
Tony ED8 wrote:Thanks dude this helps a bunch. Do you know how/where i can get OEM interior parts like Climate Control and the center dash piece :?:
I am unsure where I found this, but this site pretty much has a lot of interior parts.
http://parts.sonshonda.com/default.aspx
tparsons08
Postby Baker » Mon Jul 23, 2012 7:54 am
tparsons08 wrote:I am unsure where I found this, but this site pretty much has a lot of interior parts.
Most if not all items are discontinued and a lot of the online Honda parts dealers list the parts, actually having them is a different story, which is why it is best to call and confirm that the part is available.
Postby RosaRex » Mon Aug 27, 2012 3:29 pm
Did 1990 Crx Si come with electric windows?
RosaRex
Postby Baker » Tue Aug 28, 2012 7:15 am
RosaRex wrote:Did 1990 Crx Si come with electric windows?
This list refers to US models.
But no, not on cars this side of the world.
It was available on cars available in Europe and Japan.
Postby IZZY13 » Sat Sep 08, 2012 10:59 pm
After reading this entire thread I'm convinced I have a "Frankinrex"!
I have an 89 HF.
The front bumper looks like the 90-91.
It has:AC, Passenger side mirror & Timer on rear defrost.
IZZY13
Postby Baker » Mon Sep 10, 2012 7:51 am
IZZY13 wrote:After reading this entire thread I'm convinced I have a "Frankinrex"!
I have an 89 HF.
It's really no big deal, especially since the car is nearing 25 yrs old and has had a few owners.
Unless you're telling us you are the original owner and purchased the car this way new. If that's the case the AC, mirror and timer are a non issue.
-Bumper cover can be easily swapped at one time or another.
-All model Crx's were available with AC, some got it, some didn't.
-Passenger mirror could have easily been added along the way, either by the owner or the dealership.
-As far as I know, the timed rear defrost was standard.
Postby SnowDrift » Wed Sep 19, 2012 8:14 pm
Just curious, as this is all good info and all, but I was wondering if any interior bits between 88-91 crx and 88-91 civics (coupe/hatch) are interchangeable???
Also, you said the 88-89 CRX DX had a D15B2 engine. Mine says D15B1... Is there a difference? The car has 290k on it, though apparently the engine only has 100k. So maybe it's an engine out of a different Civic?
Edit: Uggg.. Just looked it up. It came from an 88-91 civic hatchback.. only has 70hp... no wonder my crx seems so underpowered compared to a different DX I drove. Oh well... I'll live I guess.
SnowDrift
Postby Baker » Thu Sep 20, 2012 5:13 am
SnowDrift wrote:-Just curious, as this is all good info and all, but I was wondering if any interior bits between 88-91 crx and 88-91 civics (coupe/hatch) are interchangeable???
-Also, you said the 88-89 CRX DX had a D15B2 engine.
1. See here:
viewtopic.php?t=5068
2.I didn't say 88-89, it's 88-91.
Postby 94eg! » Thu Nov 29, 2012 11:06 am
Has it been noted that the 88-89 "NH83L Off-black" interior is different than the 90-91 "NH167L Graphite Black" interior?
The pieces from the 88-89 seem to have a greenish tint to them while 90-91 have a bluish tint. I know cause I put a 90-91 dashboard in my 89 and it doesn't match.
94eg!
Postby Baker » Thu Nov 29, 2012 3:20 pm
94eg! wrote:Has it been noted that the 88-89 "NH83L Off-black" interior is different than the 90-91 "NH167L Graphite Black" interior?
It has now, thanks.
:yeah:
