quick tranny question
Car talk not CRX related goes in here.
Postby neo27ny » Wed Apr 08, 2015 10:10 am
I drained my '97 accord manual tranny to change a cv. I went to fill it back up and I can only fit about half the amount back in? Is there a third access bolt or hole? Maybe someone filled it higher up and put too much in? From what I see online the lower bolt is the drain and the one higher up with the 3/8 notch for the ratchet is the fill hole. Any ideas? Should I just start over and drain it completely and fill it to the fill hole? That's the way I've always done it on my hondas, drain it and fill until it comes out the fill hole. BTW I'm using GM synchromesh, I heard that was ok to use.
It is the world that has been pulled over your eyes, to blind you from the truth.
What truth?
That you are a slave. Like everyone else, you were born into bondage, born into a prison that you cannot smell, or taste, or touch. A prison for your mind....
neo27ny
Re: quick tranny question
Postby jfrolang » Wed Apr 08, 2015 11:59 am
You're doing it right. It was probably overfilled before.
jfrolang
Site Admin
Return to Everything Else Automotive
