Help on 1987 DX project!
Postby BlueCarbon » Tue Oct 20, 2015 9:33 pm
My boss at the repair shop I work at has a 87 DX he is willing to sell and i'm debating getting it as a project car. I've done some research and Id like to swap the engine for a D16a1 from a first gen integra. The only problem is that the crx is an automatic. Id like the d16 swap but also swap the trans for the manual. Any advice? Walk through directions? Parts list? Any comment would be greatly appreciated. I'm also new to this site so if there is a post already on anything that i mentioned, let me know!
BlueCarbon
BlueCarbon
Re: Help on 1987 DX project!
Postby solorex » Wed Oct 21, 2015 2:21 pm
Head on over to www.RedPepperRacing.com and start reading. I recently acquired an 87 DX as well which I will be converting to MPFI for a B-series swap.
The d16A1 is "basically" a straight drop in, however I am assuming you are converting to MPFI. If you are, you really need a donor 87-89 Integra to get all the parts. Keep in mind you need to drop the fuel tank and run a high pressure pump and lines also.
solorex
Postby BlueCarbon » Thu Oct 29, 2015 8:33 pm
Alright, I will. Would I be able to keep the crx gauge cluster or would I need an integra's?
BlueCarbon
BlueCarbon
Postby solorex » Mon Nov 02, 2015 2:21 pm
Should be able to keep the CRX cluster, just have to match the cluster to the type of speedo you end up using in the tranny (cable vs. electric).
solorex
Postby BlueCarbon » Tue Jun 14, 2016 7:36 pm
I know that the zc motor is slightly different from a standard d16a1 but would it still fit and mount like a d16 would?
BlueCarbon
BlueCarbon
Return to 1st Generation CRX
Users browsing this forum: Google [Bot] and 1 guest
