Problems
Problems
Postby dylanstapleton11 » Fri Mar 11, 2016 1:42 pm
I have a 87 crx si 1.5 runs fine free revving take it down the road starts breaking up real bad can push clutch in let it go to idle and go again and it's good for a Lil bit new fuel pump and filter and whole fuel system cleaned any ideas?
Sent from my SAMSUNG-SM-G928A using Tapatalk
dylanstapleton11
Re: Problems
Postby windraver » Fri Mar 11, 2016 3:41 pm
dylanstapleton11 wrote:I have a 87 crx si 1.5
any ideas?
Line breaks or punctuation would certainly help.
So the car runs fine at idle but it "breaking up real bad" when driving?
What do you mean by "breaking up real bad"? A lot of shaking? It wants to stall out? it loses power?
More descriptions please. Or consider video.
Wind's Pop-up Headlights
windraver
Re: Problems
Postby sciroccosteve » Sat Mar 12, 2016 6:25 pm
check timing.
Let the fools have their tar-tar sauce.
86 Rex
00 V6 Passat
79 Porsche
sciroccosteve
Re: Problems
Postby dylanstapleton11 » Sun Mar 13, 2016 4:41 pm
Don't have a video right now . The car will run fine until about 3,500 rpms.
When I say breaking up it acts like it loses a cylinder.
Compression check turned out good.
has new fuel pump and filter on it with whole fuel system cleaned.
Will post video tomorrow
dylanstapleton11
Re: Problems
Postby sciroccosteve » Mon Mar 14, 2016 4:37 pm
dylanstapleton11 wrote:Don't have a video right now . The car will run fine until about 3,500 rpms.
check timing
86 Rex
00 V6 Passat
79 Porsche
sciroccosteve
Re: Problems
Postby dylanstapleton11 » Mon Mar 14, 2016 6:54 pm
https://vimeo.com/158994314
dylanstapleton11
Re: Problems
Postby dylanstapleton11 » Mon Mar 14, 2016 7:54 pm
You can hear it missing and smothering out.
Its wierd it comes and goes
dylanstapleton11
Re: Problems
Postby windraver » Tue Mar 15, 2016 3:23 am
dylanstapleton11 wrote:You can hear it missing and smothering out.
I'm gonna suggest you go with what Steve said. Check timing. I had this issue before and timing was the cause.
windraver
Re: Problems
Postby dylanstapleton11 » Tue Mar 15, 2016 6:03 am
I'll check the timing but when it acts up it loses cylinder 2 . It's getting spark to it still
dylanstapleton11
Re: Problems
Postby sciroccosteve » Wed Mar 16, 2016 4:03 pm
dylanstapleton11 wrote:I'll check the timing but when it acts up it loses cylinder 2 . It's getting spark to it still
check timing.
86 Rex
00 V6 Passat
79 Porsche
sciroccosteve
Re: Problems
Postby dylanstapleton11 » Thu Mar 17, 2016 10:46 pm
check timing.
Will check timing Saturday, and post back thanks
dylanstapleton11
Return to 1st Generation CRX
