1986 CRX 1.5
1986 CRX 1.5
Postby SilentRon » Sun Aug 14, 2016 10:25 pm
Can anyone provide the common causes for a front end vibration that occurs at 70+ mph? Tires/wheels are balanced. I've swapped tire/wheel assemblies front to back and nothing changed, so I'm assuming it's not a tire or wheel problem. And yes, it's a high mileage CRX with 5 speed gearbox, so I suspect something is terribly worn. :(
Please let me know if you have questions regarding this post, or if you require additional information. Thanks in advance!
Respectfully,
SilentRon
SilentRon
Re: 1986 CRX 1.5
Postby Baker » Mon Aug 15, 2016 2:17 pm
When was the last time the car was aligned?
Check your ball joints, tie rods.
Do you feel it while braking?
Is it a vibration from side to side or up and down?
Re: 1986 CRX 1.5
Postby 1stGenGuy » Sat Sep 03, 2016 3:58 pm
To check tie rod tips and ball joint integrity: 1. Jack up front of car until wheels are off the ground. 2. To check tie rod tips, grab each wheel with two hands left and right and wiggle. If tie rod tip is worn, it will be loose-replace. 3. To check ball joint wear, grab top and bottom of each wheel and wiggle up and down. If loose ball joint is worn-replace lower arm.
1stGenGuy
Re: 1986 CRX 1.5
Postby SilentRon » Sat Sep 03, 2016 11:12 pm
The car has not been aligned to my knowledge. I do not feel the vibration while braking. Please let me know if you have further questions. Thank you.
Respectfully,
SilentRon
SilentRon
Return to 1st Generation CRX
