Help Please
Help Please
Postby J.Laha » Wed Sep 21, 2016 8:32 pm
Alright so first time posting but does anyone know how to add more oil to the car i took the oil cap off i just don't know if i am supposed to pour it directly in the engine or if i am supposed to pour it in a hole somewhere. also can someone tell me how to replace the struts that hold my hatch up?
I have a 1st gen 1986 crx just the base stock model
Its the original engine and i have a set of Showa struts that came off another 1st gen that my grandpa had
J.Laha
Re: Help Please
Postby Myriad » Sun Sep 25, 2016 7:50 pm
Yeah, just pour it right in. I understand it might look weird, but that's seriously where we pour it.
The hatch lift dampers will be bolted to the body and have a snap-clip fastener on the lift-gate. The top will pop right off with a forceful hand. There should be a plastic cover over the bolted part of the damper; pop it off and you just un-screw it.
Be careful, the lift-gate is surprisingly heavy. Try to get another person help you so you have replace the dampers without it falling on your hands or head.
Myriad
Re: Help Please
Postby Baker » Mon Sep 26, 2016 7:19 am
Good rule of thumb....
-Be sure to check the oil when the motor is cold.
-Top dot on the dipstick is full, bottom usually means is a quart low.
Take oil cap off, add oil in small amounts, let oil make it's way down into the motor, about a minute or two, check oil level on dipstick, add oil as needed.
Return to 1st Generation CRX
