Community Machining Projects Discussion
Re: Community Machining Projects Discussion
Postby NovaVTEC » Wed Aug 26, 2015 1:32 pm
Verg interesting. Seems there is some more to play with when it comes to alignment. Mine always had 0,5 degree caster difference while everything is straight...
These are the plates I was talking about:
NovaVTEC
Postby As I Conspire » Wed Aug 26, 2015 2:01 pm
Photo doesn't work for me. I'm on tapa
Sent from my XT1080 using Tapatalk
As I Conspire
AIC Designs
Postby NovaVTEC » Wed Aug 26, 2015 2:12 pm
Dropbox on android and public links... Does not work... I'll repost later from my pc
NovaVTEC
Postby NovaVTEC » Thu Aug 27, 2015 5:06 am
Here's the pic:
NovaVTEC
Postby raffaelli » Thu Aug 27, 2015 7:41 pm
There is alot of wiggle room in the mounting holes on the cross member. You get be out of wack side to side by several degrees in caster.
We once hooked the winch to the cross member to pull it up onto the trailer and it altered the caster a bit. Since then we have squared it to the chassis and tack welded it in place just to prevent it from shifting. Whe we need to remove the member, we just grind off the tacks.
raffaelli
Postby As I Conspire » Mon Aug 31, 2015 2:06 pm
OK im gonna get a print in to the boss tomorow for the bushing sets. I may be able to crank out 1000 a day but its 60 an hour plus material. So I'll probably do a run of 100 (25) sets.
As I Conspire
AIC Designs
Postby As I Conspire » Tue Sep 01, 2015 1:52 pm
Boss is giving me a quote now.
As I Conspire
AIC Designs
Postby As I Conspire » Tue Sep 01, 2015 9:13 pm
Alright guys, me and Meech have been putting in some serious time to get things a little more organized. here is a list of all vehicles that are able to use my pedal assembly bushings!
there may be a few missing but thats why i have opened up cells 63-100 for you guys to make edits. take a look at the list.
ALSO! meech and i are working on handing in a more refined version of this list to some companies in the hopes that i can sell these parts to them in bulk for them to sell in their stores! we will see how that guys. ill keep you guys posted, heres the link.
AIC BUSHING APPLICATION LIST
As I Conspire
AIC Designs
Postby Niick Nack » Sat Sep 19, 2015 1:46 am
Any idea when you're gonna start pumping out some more bushings?
Niick Nack
Postby As I Conspire » Wed Sep 23, 2015 11:18 pm
Within a month I'll be putting some serious time in. Looking into making 250 sets. Gonna be a [crud] ton haha
As I Conspire
AIC Designs
Also sorry for the delayed response. Get the word out that these are coming back!!!
As I Conspire
AIC Designs
Postby Niick Nack » Thu Sep 24, 2015 12:08 am
Nice! Can't wait! I hate this freakin pedal squeak lol
Niick Nack
Postby As I Conspire » Thu Sep 24, 2015 12:08 am
You looking into full mod?
As I Conspire
AIC Designs
Postby As I Conspire » Mon Sep 28, 2015 11:18 pm
Another step in the right direction. Looking at hopefully starting my huge run of all mod materials by the end of October. Just in time for holiday shopping :)
As I Conspire
AIC Designs
Postby Gr8_EE8 » Thu Oct 08, 2015 10:35 am
Put me down for a full pedal mod. When will you be starting the next run?
Sent from my SM-T800 using Tapatalk
Gr8_EE8
Postby Geezy1014 » Fri Oct 09, 2015 7:02 pm
What exactly does the shifter bushing do? Im considering buying one.
Sent from my MT2L03 using Tapatalk
Geezy1014
Postby As I Conspire » Mon Oct 19, 2015 6:17 pm
That aluminum piece replace the rubber bushing on the underside of the car. It will give you less slop in the shifter at the sacrifice of comfort. You will feel vibrations from the engine and trans. The zero slop mod is actually a very highly recommended modification that replaces the u joint in the linkage and take out more slop, no cons with that. Just less slop. If you did both, expect a big increase in the feel of your shifter. I would go against the aluminum piece as over time the aluminum will wear out and may bind up. Especially if you live anywhere that salt is sprayed on the roads. If it were a bronze price I say go for it
As I Conspire
AIC Designs
Postby Niick Nack » Mon Oct 19, 2015 11:52 pm
As I Conspire wrote:You looking into full mod?
Just looking to get the clutch pedal bushings.
Niick Nack
Postby Exelbaradin » Tue Oct 20, 2015 12:51 am
i know i am
Exelbaradin
Postby As I Conspire » Wed Oct 21, 2015 8:13 pm
No worries guys. I know noone is into tearing the cars apart during the winter so if you don't rush me we won't have issues. Programming is all done and just waiting on me to order the material and have it sent
As I Conspire
AIC Designs
Postby Niick Nack » Tue Jan 26, 2016 12:31 am
Just wondering if there are any updates?
Niick Nack
Postby de.abeja » Sat Jan 30, 2016 1:30 pm
I emailed him a week ago and haven't heard back.
Its looking like he has too much real work to put time into pet projects.
de.abeja
Postby AsianRacerX » Tue Mar 29, 2016 6:20 pm
Put me down for a set. I hate the nosie my pedals make
AsianRacerX
Postby KMFDM781 » Mon Nov 28, 2016 3:44 pm
I really need a set of these clutch pedal bushings!
KMFDM781
Postby As I Conspire » Tue Mar 28, 2017 12:37 am
I absolutely HAVE not forgotten about the community. I absolutely HAVE let work and life get in the way for a long time.
But thanks to the consistent amount of people contacting me for this. I'll be putting in some serious effort to get back into it.
At this point, expect some sort of progress within 1-2 weeks.
I have also drafted a completely new design for the accelerator side of the leadfoot assembly that I WILL be making and testing.
Also. I would like updates on those of you who have had these running for a while. Any issues?
And lastly. Next time. I take an extended absence, kick me in the ass. Those of you who have direct contact with me, don't let it slide. Call me up and tell me to get my bitch ass to work.
Yes, I'm still alive, were gonna get these projects Alive again.
As I Conspire
AIC Designs
Return to Modification Garage
Users browsing this forum: Bing [Bot] and 6 guests
