Coolant (smoke) coming out the exhaust .????
Postby Jdmcrxb20 » Wed Dec 28, 2016 7:01 pm
What's crx fam I just finished building a poor mans type r gsr block B16a head did a complete rebuild I used a cometic head gasket doesn't leak oil nor coolant but there's white smoke coming out my exhaust with the smell of coolant I don't see any coolant in my oil nor oil in my coolant ..I did notice after an hour or so I have to add more coolant due to it being burnt .now what should I look for??? with this be a bad headgasket or a bad resurface on the head which it did get resurfaced according to the machinest.
Jdmcrxb20
Re: Coolant (smoke) coming out the exhaust .????
Postby raffaelli » Wed Dec 28, 2016 11:18 pm
Sounds like you have coolant leaking into a cylinder. You can check this with a bore scope to see which cylinder is cleaner than the others.
If this is the case, pull the head and see where the water path is. Hopefully, it is either a bad seating of the gasket or a warping of the head. If it is the block that is not flat you will need to pull the engine.
raffaelli
Postby Jdmcrxb20 » Thu Dec 29, 2016 10:12 am
It's not the block it got decked and honed ..I'm leaning towards the head gasket .now if it's a wrapped head is that fixable .?
Jdmcrxb20
Postby raffaelli » Thu Dec 29, 2016 11:38 pm
You got the block decked but not the head? Was there a reason you didn't?
raffaelli
Postby Jdmcrxb20 » Wed Jan 04, 2017 7:08 pm
That's the thing I did send the head to get resurfaced and 3 angle valve job ..I'm guessing they didn't do a good job resurfacing the head ..
Jdmcrxb20
Postby RaulH » Tue Jan 24, 2017 5:10 pm
The coolant passage on your manifold gasket (Intake)
RaulH
Return to Modification Garage
Users browsing this forum: Bing [Bot] and 3 guests
