B-swap, check my plan before I shoot myself in the foot
Postby grouch » Sat Dec 31, 2016 3:16 pm
Help an old-timer out...
Currently: B18b, y1 tranny, obd-1/Hondata
New setup: B20z, ITR tranny, keep obd-1/Hondata
q1: I'm currently using the SK7 (usdm 90-93 teg) intermediate shaft. I can reuse that, right?
q2: 90-93 non-abs axles still?
q3: I was using a 90-91 teg clutch...still good, or 92-93, or something else?
q4: Not sure what year flywheel is currently in there...can anyone say what should work?
I'm pretty stoked about the new tranny...its a brand new, still in the oem box, never installed type R. "Only" 4.4, but I can certainly live with that.
bite me
grouch
Re: B-swap, check my plan before I shoot myself in the foot
Postby Myriad » Sat Dec 31, 2016 6:36 pm
http://winhpde.com/tech/civic/ef-honda/EFB20swap.html
It sucks that the pictures are gone, but the info is still there. It should answer a couple questions.
The 90-91 clutches used a smaller input shaft size. They will not work with bigger shaft on the ITR tranny.
Myriad
Postby grouch » Sat Dec 31, 2016 7:19 pm
Thanks...that confirms what I suspected on the clutch. I already ordered a 92-93.
I've seen that article before (and its good info) but they're obd0 and cable tranny. Most of my concerns are around the hydro tranny conversion.
bite me
grouch
Postby jfrolang » Sat Dec 31, 2016 10:07 pm
You can re-use your intermediate shaft and axles, but you will need to change the axle seal on the transmission to match that mid-shaft.
92+ clutch as you already know, and all B-series flywheels are interchangeable.
jfrolang
Site Admin
Postby grouch » Sat Dec 31, 2016 10:48 pm
Ah, there's a name i recognize. This is davens/Ni. Been away awhile.
Thanks for the confirmation...will try the 90-93 int shaft seal.
bite me
grouch
Postby grouch » Sat Feb 11, 2017 9:06 pm
Whew. It's in and running...got some potential.
Got some crower cams ordered and dyno time scheduled.
Cosmetics up next.
bite me
grouch
Return to Modification Garage
Users browsing this forum: Bing [Bot], Google Adsense [Bot] and 5 guests
