Door to pillar mount seatbelt conversion?
Postby CRXLURKIN » Tue Feb 07, 2017 2:57 pm
Are there any current write ups on a door to pillar seatbelt conversion? With pictures? All I found were like 2008 articles and the pictures won't load. Thank you!!
CRXLURKIN
Re: DOOR TO PILLAR MOUNT SEATBELT CONVERSION
Postby Gophat » Tue Feb 07, 2017 8:10 pm
Well all the B Pillar trims should come with the hole markings embedded into the plastic You use that trim piece to mark the B pillar and you can weld in your nut to the frame where the top seat belt point mounts to. I don't know if the floor portion of the seat belt is marked but it should be linear to the top one. If you can weld you can do it. As far as the doors, you have to remove all the brackets and mechanisms that come in the 89+. Maybe salvage some 88 door panels to cover the holes that are left behind. As far as the latch it should be the same. After that I don't think there is much left.
I don't have any pictures but I do own an 1988 and I can snap some pictures for you if you would like? :-)b
1988 Honda CRX DX
Feedback Page
Gophat
Postby Baker » Wed Feb 08, 2017 8:46 am
Is this helpful?
viewtopic.php?t=40734
Postby CRXLURKIN » Wed Feb 08, 2017 3:18 pm
Thank you for the help! What seatbelt do I start with? Has to be CRX, or will any civic belts work?
CRXLURKIN
Postby nihkon » Wed Feb 08, 2017 3:25 pm
Baker wrote:Is this helpful?
That's a similar write-up to the one I referred to when I did this to my old white CRX 10+ years ago. Pretty easy job if I recall.
CRXLURKIN wrote:Thank you for the help! What seatbelt do I start with? Has to be CRX, or will any civic belts work?
That info is in the thread that Baker linked to. :-)b
nihkon
Moderator
Postby CRXLURKIN » Wed Feb 08, 2017 4:33 pm
Ya, just read every comment. saw 92-95 civic belts will work
CRXLURKIN
Postby CRXLURKIN » Wed Feb 08, 2017 4:34 pm
Looks like its going to be a far reach back for the belt, once installed.
CRXLURKIN
Return to Modification Garage
Users browsing this forum: Google Adsense [Bot], Iczer_EF8 and 5 guests
