Turbo map sensor?
Turbo map sensor?
Postby Crxtremecrx » Wed Mar 01, 2017 8:53 am
I am getting a few different answers when I talk to people or do a search. I am 89 d16a6 with turbo. I am obd1 with newest hondata. I hope to run 15psi or more. Do I need a new map sensor or is the stock one going to work or should I swap to a 92 intake with one on the tb
Crxtremecrx
Re: Turbo map sensor?
Postby jfrolang » Wed Mar 01, 2017 11:04 am
None of the stock MAP sensors will properly read 15 psi. Hondata and AEM sell 4-bar sensors, or the budget option is the GM 3-bar.
jfrolang
Site Admin
Postby Crxtremecrx » Wed Mar 01, 2017 12:51 pm
So I will need to swap intake manifolds and what not then?
Crxtremecrx
Postby jfrolang » Wed Mar 01, 2017 1:01 pm
Who said anything about swapping the intake manifold? No you don't need to do that.
jfrolang
Site Admin
Postby Myriad » Fri Mar 03, 2017 3:52 am
Go to the junkyard and pick up a GM 3-bar MAP. Perfect to use with hondata and cheap.
Myriad
Postby daveb91 » Sat Mar 04, 2017 9:31 pm
Map reads off a vacuum line from the manifold.
daveb91
Postby Crxtremecrx » Mon Mar 06, 2017 6:35 pm
Ok So I got the sensor in the other day. I was told not to install it till I am at the dyno shop or the car won't run right on hondata.
Crxtremecrx
Postby signalpuke » Mon Mar 06, 2017 6:39 pm
I thought that Hondata had a drop down for selecting the sensor type? Should be able to install it and just change the setting in the software.
I haven't played with the Hondata software in years, so double check.
signalpuke
Postby Crxtremecrx » Mon Mar 06, 2017 8:54 pm
I didn't do the first setup on my laptop. I heard if I hook up and try to change it. It will erase everything that is already programmed.
Crxtremecrx
Postby signalpuke » Mon Mar 06, 2017 9:29 pm
They have that 'tuner' lock-out bs on Hondata? Call your tuner, request the tune, or have them come and download it and give it to you. Then don't use that tuner again.
signalpuke
Return to Modification Garage
Users browsing this forum: Bing [Bot], Google [Bot] and 7 guests
