Rear wiper motor upgrade/conversion possible
Postby jehazimo » Wed Mar 15, 2017 4:01 pm
:help: I have an 89 crx si that originally had the hatch wiper and motor. Original owner had accident and replaced with a hatch with no wiper. If I buy a motor and the wiper arm could I have the mechanic "drill" a hole and install? Wouldn't be original but hoping to do it without havg to buy a whole new hatch. :shrug:
jehazimo
Re: Rear wiper motor upgrade/conversion possible
Postby Rommel » Wed Mar 15, 2017 11:53 pm
Just put a glass sealant/coating on rear glass and don't worry about it...
1990 CRX DX A/T to M/T Swap & B16B
http://crxcommunity.com/viewtopic.php?f=26&t=55978
Rommel
Postby raffaelli » Thu Mar 16, 2017 11:46 am
jehazimo wrote::help: I have an 89 crx si that originally had the hatch wiper and motor. Original owner had accident and replaced with a hatch with no wiper. If I buy a motor and the wiper arm could I have the mechanic "drill" a hole and install? Wouldn't be original but hoping to do it without havg to buy a whole new hatch. :shrug:
Yes you can do that. Pull the inner trim piece off to be sure the mounting points for the motor are there.
raffaelli
Postby jfrolang » Thu Mar 16, 2017 6:18 pm
Another thing to consider is the hatch's wire harness. If it was kept original to the car, you'll be fine. If the harness was swapped with the hatch, the wires won't be there for you to plug the motor into.
jfrolang
Site Admin
Return to Modification Garage
Users browsing this forum: Bing [Bot] and 2 guests
