Spring rate advice???
Postby Rommel » Wed Mar 15, 2017 11:51 pm
Getting my CRX back on the road this spring/summer and need to put new suspension on. I sold my Skunk2 Pro-C coilovers because well, wasn't happy with them. After reading up here about shocks & spring rates, which I should have done first, I have decided to go with Koni Sport with Ground Control coilover conversion. Its not daily driven or tracked yet?. But want good handling with comfort as a slight compromise. That said I was thinking 300/400 spring rate. Thoughts??
I was referencing this topic:
http://crxcommunity.com/viewtopic.php?t=4900
1990 CRX DX A/T to M/T Swap & B16B
http://crxcommunity.com/viewtopic.php?f=26&t=55978
Rommel
Re: Spring rate advice???
Postby crocrx » Thu Mar 16, 2017 3:32 am
350f 250r
You said comfortable.
crocrx
Postby raffaelli » Thu Mar 16, 2017 11:45 am
I believe the OE rates are 250/150. So as suggested 350/250 is a stiffer ride that may be comfortable.
Do the Koni Sports accepted a coil over kit? I think they have the OE perch mounts?
raffaelli
Postby Rommel » Thu Mar 16, 2017 6:23 pm
raffaelli wrote:Do the Koni Sports accepted a coil over kit? I think they have the OE perch mounts?
It shows it is from dropdown menu.
http://www.ground-control-store.com/products/description.php/II=877/CA=71
Rommel
Postby daveb91 » Thu Mar 16, 2017 8:20 pm
I had a koni GC combo of 450 550.....it was surprisingly fine.....for a third car suspension.
daveb91
Postby Mista Bone » Fri Mar 17, 2017 1:44 am
Neuspeed/H&R soft sports on OEM style replacement shocks are perfect for a 1800 lb car.
H&R race on Koni Yellows in same CRX, you'll get beat up over same 1500-2000 mile drive.
Everyone wants a "tite boy" ricky ricer suspension until they have to drive the car any distance. Mind you I have many SCCA ST/STS customers that do exactly that.
Save me a spot a Lincoln, save me a cold beer!
BoneSpec Transmission
"D" Tranny guru
Mista Bone
Postby Tasos_7R » Fri Mar 17, 2017 6:46 am
Mista Bone wrote:Neuspeed/H&R soft sports on OEM style replacement shocks are perfect for a 1800 lb car.
Any suggestion on OEM shocks that can hadle the lower springs?? KYB Excel-G perhaps??
Frost White CRX 1.6i-VT EE8
Tasos_7R
Postby raffaelli » Fri Mar 17, 2017 7:37 am
I could be wrong but Tire Rack shows an OE perch
https://www.tirerack.com/suspension/sus ... 17123621:s
raffaelli
Postby Dr. D » Wed Mar 22, 2017 6:09 pm
I went 430f 380r with ots Koni shocks, ground control kit with tophats. These were the rates suggested by ground control, based on our conversation about my intended use. Rides great, if not a bit harsh on rough roads. I also have the ability to swap spring f to r to get the rear to rotate a little better during autox.
Dr. D
Return to Modification Garage
