VX transmission in HF
Postby wspangle » Fri Mar 24, 2017 1:39 pm
Is it possible to put a transmission from a Civic VX into a stock CRX HF? It is hard to find an HF trans, let alone rebuild kits, but I want better fuel economy than the SI trans is giving me.
If it is possible, how much work is involved?
wspangle
Re: VX transmission in HF
Postby Baker » Fri Mar 24, 2017 2:31 pm
You need mounts and convert from cable to hydraulic...
http://www.swapshopracing.com/contents/en-us/d590.html
Postby wspangle » Fri Mar 24, 2017 2:59 pm
Which mounts exactly? I have the D15B6 engine.
wspangle
Postby jlicrx » Fri Mar 24, 2017 5:49 pm
wspangle wrote:Which mounts exactly? I have the D15B6 engine.
you need this:
http://hasport.com/store/index.php/moun ... efdhc.html
ZCspeed Racing
jlicrx
Postby wspangle » Fri Mar 24, 2017 6:22 pm
Thank you.
Now, anybody have a step by step for the process? This is my very first Honda and first time doing a transmission swap that requires modifying.
wspangle
Postby msc » Fri Mar 24, 2017 8:52 pm
Your giving up on finding an HF transmission far too easily. They are scarce but if you keep an eye out long enough one will turn up. I think it will be much easier in the long run to find the transmission you want then do a VX swap.
There are probably people that would be game to trade your trans for an HF trans.
There is nothing special required for a basic HF trans rebuild. As long as the gears are good the rest of the parts are common D series trans parts.
Mike
msc
Postby JMZ401 » Wed Apr 05, 2017 10:17 pm
I'm running a VX motor and trans. While the swap was smooth and the hydro adapter has been trouble free for over 3 years, I would encourage you to keep looking for the HF trans. That is unless you're ever in central Florida, then I'd just trade you lol.
Sent from my Z981 using Tapatalk
JMZ401
Postby Nuckingfuts » Sat Apr 08, 2017 12:36 pm
I have an HF transmission for sale. NY here
Nuckingfuts
Postby Mista Bone » Sun Apr 09, 2017 12:01 am
msc wrote:Your giving up on finding an HF transmission far too easily. They are scarce but if you keep an eye out long enough one will turn up. I think it will be much easier in the long run to find the transmission you want then do a VX swap.
Mike
You forget one MAJOR thing, the shift forks are no longer available from the dealer for 88-91, 92-95, and 96-00 D series transmissions.
I bought up everything that could be found by the computer searches through HPD.
That said, I would keep the cable setup and not try a Hydro swap. HF 2.95 FD swap into a DX trans will make it a more "friendly" daily driven transmission.
BoneSpec Transmission
"D" Tranny guru
Mista Bone
Return to Modification Garage
Users browsing this forum: Bing [Bot], Google Adsense [Bot] and 5 guests
