runs rich, fouls plugs
Postby mholeshot » Sun Apr 16, 2017 9:43 pm
I have a 1985 CRX Si, #40 Jackson cam, aftermarket O2 sensor, matched injectors, tri-Y header, no cat. Out of the blue it started to stumble under heavy acceleration. It got progressively worse as I drove, plugs were fouling. I have replaced the cap, rotor, plugs, coil, distributor, wires, fuel pressure (aftermarket pump) is at spec measured with a Honda gauge. No codes in the ECU.
This is something that happened years after all the mods were put it place.
Suggestions? Comments? Thoughts?
mholeshot
Return to Modification Garage
Users browsing this forum: No registered users and 12 guests
