K20 swap?
K20 swap?
Postby Hollywoood » Mon Jul 04, 2011 9:10 pm
I'm new to engine swaps. I've been looking around at everyones swaps and i've started to wonder, how complicated would it be to swap a K20 with tranny out of an Si into a crx?
Hollywoood
Re: K20 swap?
Postby KOTUS » Mon Jul 04, 2011 9:17 pm
If your new to swaps, then I recommend you attempt a DOHC ZC swap first (easiest), then a B16A when the ZC dies (moderate difficulty), then you should know your way around to do a K swap (a little harder than a B but also a LOT more expensive)
KOTUS
Re: K20 swap?
Postby daveb91 » Mon Jul 04, 2011 9:17 pm
Not too bad just more money than a b swap... If you get the mounts and ecu conversion kit/ harness it's not too bad.
daveb91
Re: K20 swap?
Postby Hollywoood » Mon Jul 04, 2011 9:25 pm
Would an H22 swap be equally as challenging?
Hollywoood
Re: K20 swap?
Postby NikZak » Mon Jul 04, 2011 9:28 pm
in a word, yes
B16A/Y1 LSD swapped ED9
NikZak
Re: K20 swap?
Postby ironmonkey11687 » Tue Jul 05, 2011 4:40 pm
It actually isn't as bad as people think. I agree with with daveb91, as long as you have mounts, harness, and axels, everything pretty much falls into place. 5 years ago, when i did mine, it was alot harder due to the fact that we had to make our own brackets, try different axles, and wire up the harness ourselves. Now, my buddy and i can pretty much have a running k-series car in less than 2 days. Let me know if you have any question.
The little CRX that could....
ironmonkey11687
Re: K20 swap?
Postby mtflyboy25 » Tue Jul 05, 2011 5:07 pm
From what I have seen man, swaps arent that bad if you get the wiring done. Mounts axles and everything is all currently available.
mtflyboy25
Re: K20 swap?
Postby Hollywoood » Tue Jul 05, 2011 9:17 pm
Thank you all :D , If i was to find a k20 with an adjacent 6 spd, should i also pull the computer and wiring harness out of the car?
Hollywoood
Re: K20 swap?
Postby mtflyboy25 » Tue Jul 05, 2011 10:33 pm
YEEEEEEEEEEEEESSSSSSSSSSSSSSSSSSSSSSSSSSSSSS
mtflyboy25
Re: K20 swap?
Postby Tian90crx » Tue Jul 05, 2011 10:38 pm
you still need to flash it, need the rear crossmember cut.. i don't think the stock header will work.. mounts, axles, re-do fuel lines, adjustable shifter (not sure if needed), relocate prop valve (brakes) cuz it hits the valve cover.. and also it wouldn't fit your hood if you have a usm hood, you would need a JDM whole front end to make a flush fit, or just cut the hood or use spacers.. if you are serious about it, search and search, and prepare to be broke or in debt :-)b
http://www.crxbart.com/K20swap.html
Aftermarket Quality Turbo, Suspension, interior parts FOR SALE http://crxcommunity.com/viewtopic.php?f=8&t=156674
Tian90crx
Re: K20 swap?
Postby ironmonkey11687 » Wed Jul 06, 2011 9:19 pm
here is my setup
ironmonkey11687
Re: K20 swap?
Postby Tian90crx » Wed Jul 06, 2011 9:48 pm
^^^ where.... the.... hell... is your FRKN build thread! :D
Tian90crx
Re: K20 swap?
Postby NikZak » Thu Jul 07, 2011 12:59 am
bloody oath mate, build thread with progressive pics or it didn't happen
NikZak
Re: K20 swap?
Postby mtflyboy25 » Thu Jul 07, 2011 8:46 am
yeah.. what they said ^^^^^^^^^^
mtflyboy25
Re: K20 swap?
Postby the insomniac » Thu Jul 07, 2011 12:26 pm
:shock: :-)b
'91 Rio Pink Si, DOHC ZC swap
the insomniac
Re: K20 swap?
Postby crxvtec91 » Thu Jul 07, 2011 4:00 pm
If your planning on staying N/a your going to be piss when a boosted D walks you :lol:
At least my buddy was, he made close to 300hp with a k20 head, and k24 lower end, he was piss off and all he kept saying was how he spent close to 10k and a F@$& sohc beat him, to top it off it was my pig of a 94 4dr :lol:
500hp and 450ft/lbs @30psi
crxvtec91
Re: K20 swap?
Postby ironmonkey11687 » Thu Jul 07, 2011 4:51 pm
Hahahaha sorry guys but i never made a build thread. In fact, i just recently came out of the woods with my car. I've have it running for the past 5 1/2 years. Originally, my intentions were to build a fully built b16 turbo, but i wanted to be ahead of the game and dropped the money I was going to use on the build on a freshly imported K20A Type R motor and trans. With the basic bolt-ons which consisted of :
velocity stack/headers/ 2.5 in exhaust/kpro and blue print stage 2 titanium valve springs and retainers
The car put out, final Numbers, 259 hp 184 ft lb trq at Churchs dyno.
1/4 mile i was running 11.98-12.15 consistent times
I wanted more power, so i decided to slap on this little garrat t3 60-1 .70 a/r turbo alongside with a synapse turbo manifold custom made for my car :p The car then put out 415 hp 290 ft lb trq at 10 psi on a super conservative tune.................91 oct..............DAILY DRIVEN! lol
ironmonkey11687
Re: K20 swap?
Postby mtflyboy25 » Thu Jul 07, 2011 8:22 pm
i just came.....
mtflyboy25
Re: K20 swap?
Postby NikZak » Thu Jul 07, 2011 9:04 pm
ok... take a photo of yourself in front of the car holding a coffee mug, to prove it is actually your vehicle... :)
or simply take a photo of the engine again with a coffee mug sitting on the valve cover
that's not something you're likely to find in a cursory google image search :)
NikZak
Re: K20 swap?
Postby ironmonkey11687 » Thu Jul 07, 2011 9:14 pm
:wink:
buddy's turbo k20hf
jdm front
usdm front with custom usdm hood
Thanks Nihkon for pics :-)b
ironmonkey11687
Re: K20 swap?
Postby mtflyboy25 » Thu Jul 07, 2011 9:44 pm
ok stop it...
mtflyboy25
Re: K20 swap?
Postby NikZak » Thu Jul 07, 2011 10:28 pm
nice work mate, i stand corrected :) looks f#@&!ng awesome, what sorts of times is it putting down the strip?
mtflyboy25 wrote:i just came.....
ditto ;)
NikZak
Re: K20 swap?
Postby Tian90crx » Thu Jul 07, 2011 11:27 pm
i searched google: "k20 turbo coffee mug" and this pic came up... hmmm.. ha, anyways, i would put a filter on that turbo if its as u stated daily driven..
ironmonkey11687 wrote:Image
Tian90crx
Re: K20 swap?
Postby crxvtec91 » Fri Jul 08, 2011 8:24 am
ironmonkey11687 wrote:Hahahaha sorry guys but i never made a build thread. In fact, i just recently came out of the woods with my car. I've have it running for the past 5 1/2 years. Originally, my intentions were to build a fully built b16 turbo, but i wanted to be ahead of the game and dropped the money I was going to use on the build on a freshly imported K20A Type R motor and trans. With the basic bolt-ons which consisted of :
I love the power those motors make on low boost. Its a bit funny if you think about it, what you did at 10psi took me 24psi, 408 hp uncorrect and 370ft/lbs
crxvtec91
Re: K20 swap?
Postby ironmonkey11687 » Fri Jul 08, 2011 11:34 am
NikZak wrote:nice work mate, i stand corrected :) looks f#@&!ng awesome, what sorts of times is it putting down the strip?
ditto ;)
Thank You!!! The last time I went to the track, I did not run slicks, but spinning 1-3 I managed to pull consistent times of 12.2-12.3.
Tian90crx wrote:i searched google: "k20 turbo coffee mug" and this pic came up... hmmm.. ha, anyways, i would put a filter on that turbo if its as u stated daily driven..
I would have one if one could fit :?
ironmonkey11687
Return to Modification Garage
