B18c5 SWAP in EF help!
Postby MaSSimo » Sun Apr 14, 2013 10:06 am
Hi guys. got b18c5 engine and s80 tranny.
2 years my b-engine laid in a corner of my garage. yesterday I wanted to put everything together and faced with problems
left body mount doesn't fit to the innvoite trans mount
engine...
what to do gurus? please advise
Thanx
1 picture for fun
MaSSimo
Re: B18c5 SWAP in EF help!
Postby As I Conspire » Sun Apr 14, 2013 10:57 am
very nice work so far.
here is what i would do. if you have the order number or receipts or at least the model number of the part they sent you, give them a call and make absolutely sure that you have the right kit.
if not then ask them what it will take to mount a b18c5 to an ef chassis, and see if they will take your current mounts for a return. all you can do is ask, the worst they can say is no.
As I Conspire
AIC Designs
Postby MaSSimo » Sun Apr 14, 2013 12:33 pm
As I Conspire wrote:very nice work so far.
Thanx. Anyway
I ordered http://www.innovativemounts.com/Product ... ode=B49150
The very 88-91 Civic/CRX Billet Conversion Mount Kit for B Series Engines with Hydraulic Transmission...but real life turned out that smthg is wrong... Chasis itself or there should be a spacer between engine mount and innovative mount
It is my first swap and I'm kind a noobie in such question :oops: :oops:
MaSSimo
Postby ShinCRX » Sun Apr 14, 2013 9:03 pm
B20 mounts? Maybe they sent u the wrong shhhhiiiiii et
nice brake setup
ShinCRX
Postby midious » Sun Apr 14, 2013 10:28 pm
Nice everything!!!
I want those UCA badly :P
midious
Postby MaSSimo » Mon Apr 15, 2013 2:53 am
I found why my left mount doesn't fit. because of mount supply itself (D-series) and SIR/I-VT has different one supply.
the only question left - how to put right mount with b18c5 engine :shock: :rolleyes1:
sorry for my English :oops:
MaSSimo
Postby MaSSimo » Mon Apr 15, 2013 3:36 am
took here http://www.b17gsr.ca/2003/10/installing-a-b18c5-into-a-crx-preperation/
braket on chasis also should be changed to a sir-I-VT one :twisted:
MaSSimo
Return to Modification Garage
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 7 guests
cron
