seat and harness question...time trial
Postby chagood8267 » Fri Mar 27, 2015 10:03 am
i was looking at getting the corbeau forza sports seat but had a few questions first. first off how did u guys mount it to the floor? i know it has to be on fixed mounts but not a 100% if i just drill holes or not lol. second would the kirky univeral mounts work...theyre just 45 while the corbeaus are 125. harness questions now...im gettina a 4 point put in my car this week and gonna rock a harness bar for the top but how did u mount the lap and crotch belt? i bolt in the floor? stock seat bolts? thanks for the feed back. sry im such a neub i just wanna be sure its gonna pass scca tech.
84 ls1 silverado (Junk Hauler)
06 civic (The Daily)
89 y49 crx (New to me Autox and TT car)
07 Tahoe (Baby Hauler)
91 Civic Wagon (Long way to go)
chagood8267
Re: seat and harness question...time trial
Postby Dave_Darling » Fri Mar 27, 2015 11:32 am
You can start off by reading the rules, which you can find here (click me!!).
Some general thoughts:
- Seats are now certified only with one specific set of mounts. So if you're using the Corbeau seat, there's a good chance that the Corbeau mount will be required to pass tech.
- All mounting bolts should have large washers or hard metal doubler plates. A 4" washer is not too large.
- All mounting bolts should use locking nuts, or have double nuts to prevent them from backing out.
- Harness bars are almost always only for guiding the belts. Bolt the shoulder harnesses to the floor or to the rear hatch area, rather than attaching them to the bar.
- Lap belts should be mounted to the floor, because there aren't really factory lap belt bolt holes in our cars.
- Sub strap(s) should also be mounted to the floor--but not to the same point as the lap belts.
- All belts have a range of acceptable positions, e.g., the shoulder harness is supposed to come back from your shoulder at roughly 90 degrees to your spine. Find these positions out, and make sure your belts are within those ranges. Remember, an out of position lap belt is one of the things that killed Earnhardt.
- Sub strap and shoulder belts should be going through existing reinforced holes through the structure of the seat. Wrapping them around the front or sides of the seat is a bad idea. Lap belts may or may not have their own holes as well, depending on the seat.
Finally, contact the Safety steward of your local SCCA region and have a talk with them about what is required to pass tech. They are usually pretty approachable, and they do know this stuff pretty well... ;)
--DD
Dave_Darling
Postby chagood8267 » Fri Mar 27, 2015 2:53 pm
:-)b thanks...
chagood8267
Postby tommy » Tue Mar 31, 2015 8:56 am
Yes, very informative, Dave. Looks like I'm off to get locking nuts to replace the current ones for the side mounts and the side seatbelt guides as well.
On a side note, my Momo fixedback is getting redone now, but the plastic trim piece that goes around the sub belt opening is toast, and I'm sure it will disintigrate when they pull it apart. Does anyone know where to get replacements??
