Another CRX HF for sale
Find the perfect CRX here, or post yours for sale.
Postby kracksmith » Mon Apr 10, 2017 9:40 pm
This is my daily driver for 1.5 years going 70 miles round trip from home to work all freeway miles. I now have a different job and don't need to commute quite as far so since this is my 2nd CRX I'm letting it go. Everything runs good. I still get 48/50 mpg and I drive 70mph on the freeway there and back. I use 91 octant only. Car currently has 276k mileage. Price is firm. It's manual tranny and clean title with pink slip in hand. I garage this nightly. This car is located in So Cal Inland Empires. Price 2000 firm.
Here are my maintenance below:
Clean IVAC by soaking it over night 1-16-2017 276,507
Timing belt,tensioner, and water pump done at 260,000
Gas tank swap from stock 10 gallon to 12 gallon done at 260,000. It can easily get 500 plus miles on 1 tank.
Tranny oil change at 276,270
Spark plug at 259,150
Coolant drain, filled, and bleed at 260,000
Master break cylinder changed at 256,000
Air filter k&n at 276,432
outter and inner tie rods changed at 261,200
Rack left and right boot has been changed at 261,200
New battery at 255,000
New trailing arm bushing at 255,000
Fuel pressure gauge installed to check out fuel pressure
Fuel filter installed at 273,034
Has AC and blows cold
It has this sound deading throughout the entire car. Noise is very low
EDM rear wing professionally installed with silicon
Greddy muffler, very quiet
Yakima Roof rack is NOT included
Stereo with 4 speakers, has it's own power supply off a manual switch. Did not mess with any other stock electric wiring.
4 85-90% Falken all matching tires on 15x6 steelies
Rear CRX JDM back seat, no seat belts though
Rear stock interior is complete
Rear aluminum poly bushing LCA
Rear strut bar
Tokico Illumina Strut with Eibach Spring
Alignment at 255,000
Custom cargo floor cover
Oil change every 3K
Forgot to mentioned has front cross drilled brakes rotor, rear is drums
Cons are:
doors makes a popping noise when open
driver side door fender is a little bent
kracksmith
Re: Another CRX HF for sale
Postby kracksmith » Fri Apr 14, 2017 10:55 pm
Sold
kracksmith
Return to Cars - For Sale or Trade (FS or FT)
