CRX part out list
All parts relating to the CRX. If it's from another Honda, but is commonly used for the CRX, it's ok.
CRX part out list
Postby 91pp » Tue Apr 05, 2016 9:30 am
I have the following available at this moment, and will be adding to the list as soon as I can. All parts are in NJ and available.
1991 Si brake booster, master cylinder, proportioning valve $50 SOLD 4/19
replacement antenna for 1991 $10 SOLD 5/28
1989 heater core, box and ductwork $25
8/1987-2/1989 passenger side inner front fender $15
dash insulator mat (original, not replacement) $75
88-91 passenger side A pillar dash bracket $5
1989 si wire harness (does have some damage due to additions of gauges and turbo etc) SOLD 5/15
1989 pedal assembly $50 SOLD 6/11
1989 OEM gauge cluster (tach OD speedo) $75
emergency brake cover black $75
1989 clock with housing/vents $20
1989 driver side foot rest $10 SOLD 4/30
1989 steering column/pedal brace $20
steering column sheild upper and lower $20
intermediate shaft sheild $20
1989 seatbelt lights $10
driver side change compartment $5
cigarette lighter element $5
under dash fuse box cover $20 SOLD 4/30
driver and passenger side end of dash vent covers (2) $15
grab handle w/ screws and covers $5
glove box brace $5
1989 throttle cable $5
shifter cover black vinyl $5
1989 clutch cable (manual) $5
KYB struts 341094, UJ16 front and rears made in Japan, contains Nitrogen, with adjustable coil over spring kit attached, SET OF 4 $80
A/C kit including:
1991 AC mount, aluminum for DOHC 1.6 adapter , 1991 AC compressor, MODEL NL1302AD4 [M] working order at removal no guarantees , AC lines (3 -lower suction hose removed) , receiver dryer assembly on AC line #4 $150
1989 lower strut mounts OEM set 2 $5
1989 rear lower control arms OEM set 2 $5 SOLD 4/20
1989 sway bar $10
1991 working sunroof grey int/green ext. $50 SOLD 4/21
1991 black caul cover $40
HONDA OEM tail light set 043-8326L, 043-8326R, with center "CRX" 043-8330, set 3 $100 1989-90 no damage
1991 fuel filter bracket $5
1991 OEM headlights with brackets 1 set, d/s & p/s $120 for pair
ROUND 2:
1 teal ds door vg condition 1991 $150
1 teal ps door vg condition 1991 $150 SOLD 5/12
2 gray interior roof cover/headliner w/ grey interior moonroof lipseal $40
1 tinted d/s door window glass $50
2 tinted p/s door window glass $50
1 red hatch *holes where wing was mounted 1989 & 1 teal hatch *1 hole for rear wiper OEM 1991 $50 for pair
1 red hood with p/s top peel *needs minor repairs 1989 $40
2 NEW clear lower front bumper lights/turn signals with yellow bulbs included, new in box SOLD 5/28
1 teal front bumper cover with styrofoam backing and plastic mounting brackets 1991 $90 SOLD 4/20
1 set d/s & p/s interior door sill molding NO CLIPS $30 for pair
1 set d/s & p/s rocker panel molding black NO CLIPS $30 for pair
1 center rear tail light OEM for "SI" model OEM 043-1008 2 scratches $60
1 center rear tail light OEM for "CRX" model vg condition $80 SOLD 5/28
1 header NEW IN BOX stainless steel *aftermarket new for 1.6L DOHC B series engine $175
ROUND 3:
second 1991 AC mount, aluminum for DOHC 1.6 adapter (from repair) $10
1 NEW IN BOX- DORMAN 520-611 front left upper control arm replaces MK9814 $25 fits 88-91
1989 AC evaporator with case $20
1989 Heater/AC blower motor with case $20
1 set of B pillar door moldings exterior black, some clips broken $30
1 hard plastic L shaped wire harness cover black
1 Stanley OEM 050-8375 rear third/ deck lid brake light $30
2 HVAC climate control heads (both cracked, can be repaired with cover plate) $75 each BOTH SOLD
1991 D/S and P/S set seatbelts (retractors in tact) $60 for set
fire wall insulator mat $60
NEW IN BOX- NH167L interior L shaped plastic covers color black that fit rear panels
1 UNIT: including, 1991 steering rack (rack & pinion), front cross member, sway bar, both lower control arms $100
ROUND 4:
1 set window tracks (4 pieces) $25
fuel injector resistor $30
1 rear hatch and fuel door release cable with handles and black plastic bezel $75
aluminum, plastic coated tow strap hook $10
APEXi V-AFCII Vtec control airflow converter $175
1 ECU 37820-PR4-AII / 490-141272 ABJ// Vtec added programmable ECU $200
1 rear wiper motors WM3209-1S $20 each
1 1988-91 D/S front mud flap / splash guard SH2-200-206L $50
1 1988-91 set D/S & P/S rear mud flap/ splash guard SH2RR-L206-142, SH2RR-L206-141 $80
1 ECU 1991 1.6L Si 5speed manual transmission 37820-PM6-A09 $150
1 after market battery box, boat style $30
1991 p/s rear taillight with 3 bb holes OEM 043-1009R $15
1 set (3 pieces) clear tail lights 1991 $250
1 set (D/S & P/S) front lower fender cap/ exterior molding black L71860-SH2-0000, R71860-SH2-0000 $80
1 P/S front lower fender cap/ exterior molding black R71860-SH2-0000 $40
1 set (D/S & P/S) front fender molding strip protector 75301-SH2-0030R, 75301-SH2-0030L 1990-91 $40
1 P/S front fender molding strip protector 75301-SH2-0030R 1990-91 $20
**NOTE**
If you are requesting photos, I need you to provide an email address.
If you are requesting a quote I need you to provide:
1. your zip code
2. how fast you need the item to arrive
3. what is an acceptable cost
Once those items have been provided I will inquire. Thank you.
Don't like my asking prices? They can be neg. Contact me with offers. If you are searching for something else let me know I have 2 additional units to inventory. Additional parts unlisted. You want the entire lot, make me an offer, it is available for pickup. Thanks ---L
91pp
Re: CRX part out list
Postby damonhimself » Mon Apr 11, 2016 10:11 pm
Interested in those rear LCAs. Are the bushings still good? LCA's all rusted out? Shipping to CO? :mrgreen:
damonhimself
Postby icedout » Sun Apr 17, 2016 10:27 am
Pics of the sunroof please. bam_footy@yahoo.com
icedout
Postby kracksmith » Sun Apr 17, 2016 4:54 pm
interested in the front kyb with coil over kit. what kind of coil over kit is it and how many miles on the front struts?
like to see picks, kracksmith@gmail.com
kracksmith
Postby icedout » Mon Apr 18, 2016 4:24 pm
Text me when we can meet up for the sunroof. 2158737276
icedout
Postby Yellowrex24 » Mon Apr 18, 2016 7:38 pm
Could you email me at pinguino0130@yahoo.com some pics of the tail lights, rocker panel and additional parts you may have for a 91 crx si. Thanks
Yellowrex24
Postby 91crxburg » Mon Apr 25, 2016 8:27 am
PM sent.
91crxburg
Postby blazercrx » Tue Apr 26, 2016 8:03 am
Is that 91 brake booster, master cylinder and prop valve a HF, DX, or si?
Mista Bone wrote:The only LSD is what he has been smoking!
Blazercrx feedback
blazercrx
Postby crx2mouse » Fri Apr 29, 2016 8:18 am
Interested in several parts.. Pm me when can
crx2mouse
Postby civicsir07 » Tue May 03, 2016 12:29 am
Parts still available?
civicsir07
Postby 91pp » Thu May 05, 2016 12:24 pm
Any parts not marked SOLD* remain available. pms were sent to crx2mouse and civicsir07. Thank you
91pp
Postby mattj » Thu May 05, 2016 9:29 pm
Sent you a message
mattj
Postby 91pp » Wed Aug 03, 2016 3:56 pm
bump
91pp
Postby ggardiner » Sun Sep 25, 2016 8:42 am
Hello,
didn't see it listed, but do you have a wiper linkage for an 85-87 CRX? drivers side
thank you
Gerard
ggardiner
Postby Yell88CRXsi » Sat Oct 29, 2016 10:18 am
I am looking for the dash heater ductwork just below the cluster. It is a 2 piece duck that connects the heater box to the driver's side vent.
Yell88CRXsi
Postby Myriad » Tue Dec 27, 2016 1:56 pm
I PM'd you.
Myriad
Postby jehazimo » Mon Mar 13, 2017 6:24 pm
Still have DS front fender moulding?
jehazimo
Postby shendey » Tue Mar 14, 2017 12:03 pm
Interested in 1 set of B pillar door moldings exterior black, some clips broken $30 if they are still available.
shendey
Postby 91pp » Sun Apr 02, 2017 6:59 am
****SOLD****
91pp
Postby Nuckingfuts » Tue Apr 04, 2017 8:24 pm
I will take the change compartment and there are some other interior bits that I need, not sure if everything you posted is everything you have.
Nuckingfuts
Postby Chalon91si » Thu Apr 06, 2017 3:25 am
Still have the clear tails?
Chalon91si
Postby Turtle Hermit » Tue Apr 11, 2017 5:14 pm
I need just one of the AC hoses for a 91 Matsushita setup if you're willing to part. I'll even buy all 3 hoses if you aren't willing to sell just one. I really don't need a compressor and the other stuff though. Located in NY 10606. The one I need is the suction hose.
PM me or reach me at 914-536-3119. Thanks.
Turtle Hermit
Postby 91pp » Mon Apr 17, 2017 7:11 am
pms sent reference all inquiries
91pp
Postby 4crx4me » Mon Apr 17, 2017 9:44 pm
Your list is too long to sift through. :oops:
Any 1990-1991 OEM fenders either side, any color? And/or any OEM Stanley 1990-1991 front corner marker lights, either side?
Thanks. I'm in north Jersey so if you're not too far out west I'd even take the ride out to pick them up.
4crx4me
Postby Jamm0nit » Tue May 02, 2017 10:29 am
Pictures of tail lights please.
Jamm0nit@yahoo.com
Sent from my iPhone using Tapatalk
Jamm0nit
Return to Parts - For Sale or Trade (FS or FT)
