Big 3
Big 3
Postby JDMCrx91 » Tue Mar 17, 2015 1:29 am
I want to use 0 gauge on my ALT, can I keep the stock wire and then ADD a 0 gauge wire from alt to battery with an inline fuse/breaker.
"Correct Me If I'm Wrong... That's Why I Joined" Crxcommunity.com
1991 Crx Si(turbo)
My Build Thread http://crxcommunity.com/viewtopic.php?f=26&t=34412
1991 Crx Si (sleeper) 3/17/13
viewtopic.php?f=26&t=64610
1992 240sx coupe
JDMCrx91
Re: Big 3
Postby NovaVTEC » Tue Mar 17, 2015 1:12 pm
If you want to be useless, yes you can
NovaVTEC
Re: Big 3
Postby JDMCrx91 » Tue Mar 17, 2015 5:27 pm
Useless why?
1991 Crx Si(turbo)
1992 240sx coupe
JDMCrx91
Re: Big 3
Postby KevinEF7 » Sat Mar 21, 2015 9:19 pm
It would take the path of least resistance, zero problems leaving the stock wire in place
If you have zero gauge you can use it, but even 4 gauge is quite overkill for our 60 amp alternators on a run less than 5 feet, 4 gauge quality wire can carry 150amps with little/no drop. Makes life a little easier running and hiding wires. Nothing wrong with overkill if thats your thing though
KevinEF7
Re: Big 3
Postby JDMCrx91 » Sun Mar 22, 2015 8:42 am
Thanks Kevin, yes I have 0 gauge since im installing a subwoofer. I will be replacing the alternator with either a high output aftermarket alt or getting mine rebuild for more amps. I will be installing a sundown x10 with a hifonics brutus amp at 1ohm 2000watts. Waay to much but I can always go down to 750 rms at 4 ohm.
I seen ppl doing the big 3 but wasnt sure on alt. Already did 0 gauge grounds, 0 gauge batt to starter and 8 gauge battery to fuse box.
1991 Crx Si(turbo)
1992 240sx coupe
JDMCrx91
Re: Big 3
Postby KevinEF7 » Tue Mar 24, 2015 7:12 am
What about alternator positive post to battery positive ?? (fused) thats the one where all your efforts will be noticed
KevinEF7
